Sponsored by: GEM Motorsports
Thew 228 code at 158 MPH
Old 11-18-2018, 12:08 PM
Mr. Gizmo
Mr. Gizmo's Avatar
Originally Posted by Mikec7z
read my above post. If a MAF and MAP are sensing x amount of air coming in, IF the ecu does not tell the fuel system to match it with fuel, then the engine runs lean and explodes.
It does not matter what a tuner WANTS the car to do, physics wins. Run lean, blow up.
Only way to not run lean is to pump extra fuel to meet the needs of the extra incoming o2.
When it is cold, more o2 comes in.
No, the fuel pump can't keep up on stock tune vehicles with no bolt on's whatsoever, in the proper climates and altituds. GM's test drivers did not test the car at sea level at 160mph in the cold. Or they did, and hoped none of us would. Only 2 options on the table. Either way... i call that a fail.
Yes, GM failed with flying colors
Interesting, while off topic -- On my C4Zr1- when the secondary pump for the high rpm injectors was starting to go bad, the car actually felt stronger up high but was throwing a too lean code. Then the pump went out all together.
GM really misled the buyers on these cars -- in the end there is so much that it ends up being 650 hp is less then 505 hp ---
Mr. Gizmo is offline
Mikec7z (11-18-2018)
Old 11-18-2018, 12:09 PM
Mikec7z
Mikec7z's Avatar
Originally Posted by Warp Factor
There are issues with using a stronger fuel pump. We'd run into one of them when using more powerful pumps in our supercharged C5's. The pump is cooled by the fuel, and the fuel can eventually get so hot that the pump no longer performs properly. Everything would be just fine when the fuel in the tank was cool, but after a couple of hours of driving, you'd get on it, and the fuel pressure would drop like a rock!
With the new larger pump on the Z06 and ZR1, I think GM gets around this by not putting full power to the pump all the time. Only when the computer says it's needed.
bingo
Mikec7z is offline
Old 11-18-2018, 12:17 PM
Mikec7z
Mikec7z's Avatar
now for the million dollar question...
now that I have finally explained the problem so ANYONE can follow (even people like the tuner in the southwest united states who always counters me and the other guy in the northwest who loves 2300's who always counters me... and btw... have you noticed how silent they have been this thread?!?!?!)
Million dollar question:
how long until... and who will the wise person be....
who decides it is a great idea to start a class action lawsuit against GM, which will only kill the value of your cars, and yield everyone NOTHING?
But they do it anyway, because they never matured in life beyond throwing a big fit when they find out life is not going their way, and they have been tricked.
how long until the class action starts.. and who will be dumb enough to start it?
I'm fine now, I'm immune to your choices now... my car is a lemon, they have to buy mine back. Now lets see what your experts say and do when Irun4cops and myself give them the power and the control since they FINALLY are comprehending what he and I have been talking about for over a year
Do yourselves a favor and go back and read back through ALLLL the threads where these people mocked us to no end and bragged how smart they were... and how Irun and I are clueless and our lemon cases are fake lies.... go back and read them allllll.
If i were in their shoes, i would probably commit suicide at this point
1 year ago....
"stop insulting GM, if you don't like your car, sell it! GM has a reflash, you are spreading fake BS about their cars having a problem and they don't... i know because i drive my car 80mph!!!, and sometimes I even go 135 in a straight line at the drag strip!!!!"
then 1 year later when they finally grow the brain to fathom the problem... and now they think....
"instead of just brainstorm on the forum about how to solve GM's mess up like Mike did, I'M GOING TO SUE GM!!!!!!
AND IT WILL YIELD ME NOTHING!!!!
AND I DON'T REALIZE THAT I'M NOW THE BIGGEST HYPOCRITE IN THE WORLD, SINCE I'M ATTACKING GM FAR WORSE THAN MIKE EVER DID"
Mikec7z is offline
Old 11-18-2018, 12:37 PM
3 Z06ZR1
3 Z06ZR1's Avatar
Originally Posted by Mr. Gizmo
Interesting. Gm has a conundrum. The complexity of the software , all the sensors and fuel system is too much.
as you have seen from my other threads I am a little disappointed with the performance of the car and poke fun at it. And am considering a magnuson 2300 blower. This would potentially make the problem more apparent and really would not solve much. This is probably why 3z06zr1 wants to move out of his 2015 and into a 2019.
No not at all the fuel is no issue when tuned. The stock fuel pump does on a tuned Z06 does 700 rwhp easy so it is not the fuel supply.
3 Z06ZR1 is offline
Old 11-18-2018, 12:40 PM
3 Z06ZR1
3 Z06ZR1's Avatar
That is how my z06 currently is since they tried to trick me and disable the p228c limp mode... i run 55 fuel line pressure up the tunnel when it is cold out and the in tank pump cant maintain 71psi... and as a result, instead of running rich, my car is lean and runs strong as death fast.
The other day when Roxy said my car is as fast as their zr1, they were not exaggerating.
People on this forum have not yet put 2 and 2 together why a c6z pulls well up top and a c7z does not. Its because the c7z is making choices to limit power and run rich usually. Mine no longer does (as much) it seems.
Sure ! The Stock Z06's with melted cats are every bit as fast a the ZR1 stock to stock! Wish you were here I would show you what fast is! Stock Z06? NO!
3 Z06ZR1 is offline
Old 11-18-2018, 12:41 PM
Mikec7z
Mikec7z's Avatar
Some people dont want to void their warranties, and GM's stock tune, with cats, has to run richer than your tuned car with LT headers can run, otherwise their cats melt.
Thank you for the infinite wisdom you share here with all of us. Have a nice day.
Mikec7z is offline
Old 11-18-2018, 12:47 PM
Mikec7z
Mikec7z's Avatar
never did i say my car is faster than yours.
In fact, in other threads, our pack has told you that we believe and agree that your car is faster than a stock 2019 zr1, and GM dropped the ball on that car as well.
If your car is faster than a zr1... and my car is almost as fast as a zr1... that is me agreeing you have the faster car.
Its like those logic word problems they used to give us in second grade math class. Or at least at my school they did.
Mikec7z is offline
3 Z06ZR1
3 Z06ZR1's Avatar
HAHA! AND I'm still on the STOCK fuel over 800 hp keep the expert guesses coming Such BS the tuner has added fuel with the headers not less! You sound so dumb!
3 Z06ZR1 is offline
Old 11-18-2018, 01:00 PM
Mikec7z
Mikec7z's Avatar
yes i had to wait all summer to get the code again, thats why i couldnt lemon the car yet genius boy,,, i explained that to you, over the summer. I had to wait until it got cold again.
Mikec7z is offline
Old 11-18-2018, 01:27 PM
3 Z06ZR1
3 Z06ZR1's Avatar
go drive your car slow and then come back and tell us how fast it is.
Its a new day.
We know how fast the stock car is. So off base they say the Z06 with melted CAts is about as fast as the ZR1? Like anyone pay attention to those guys!
Before the 2300 and look at the slow 60ft this car puts bus lengths on your lemon easy..
Stock blower with header intake tune. Still plenty of fuel to go past 700 rwhp on the stock fuel!
Shows what you know!
3 Z06ZR1 is offline
Old 11-18-2018, 01:50 PM
Mikec7z
Mikec7z's Avatar
When you went that fast Bob, was it on a saturday by chance?
Mikec7z is offline
Old 11-18-2018, 02:00 PM
RoxyCarter
RoxyCarter's Avatar
Did you manage to go THAT fast in a STRAIGHT LINE BOB!?!?!!?
You must be an excellent driver!
Don't fast forward to the 4:30 Mark, and don't assume anyone could pull over 1 lateral G while going as fast as 3z06zr1 Bob did in a straight line pulling 0.00 lateral G.
no one can drive as good and as fast as Bob!
RoxyCarter is offline
Old 11-18-2018, 02:17 PM
  #33
Mr. Gizmo
Mr. Gizmo's Avatar
I have been bitching about this for some time and been called a troll(which I am not).
Something is going on with these cars -- and I think you hit the nail on the head. its all in the tune, gm limiting warranty claims- and managing a supercharger(which is a not so intelligent power adder) and is why 650hp is less then 505hp up top.
I think MikeC7Z has a valid point- Basically a ZR1 is the same as a Z06 - execpt GM keeps making the pile of **** higher - more super charger, more tuning management, taking the ability away to tune the ECM in the ZR1 -etc etc.
You lean out the C7Z06 as Mike's dealer has done dealing with his repeat returns for the 228 code and "his Z06 because of the lean running condition might be more equal to a ZR1" in performance making up the 4 second difference from 0-150mph the ZR1 has.
You do the same to a ZR1 as Mike's dealer has done to his C7Z - and the ZR1 might be closer staying close on the tail of a 720S.
Old 11-18-2018, 02:20 PM
  #34
Mikec7z
Mikec7z's Avatar
let me ask you a series of tricky questions Bob...
what is the difference between a well driven zr1 and a well driven z06 in the quarter mile? (no, i'm not talking about weaponX Ben's modded zr1, i'm talking stock zr1)
Now lets ask another question, what is the difference between a stock zr1 with manual trans in the quarter mile, and a stock z06 A8 in the quarter mile... assume the guy in the a8 can drive great like you Bob.
Now lets ask another question, what happens when the guy in the stock A8's car is allowed to run lean 13.0AFR, and the guy in the manual zr1 is only allowed to run rich 10.8 AFR?
Who is quicker? Now lets say its not a sticky track that these races were taking place on... it was just normal, non sticky, street pavement, which car is faster Ray... i mean Bob?
Mikec7z is offline
Old 11-18-2018, 02:27 PM
  #35
RoxyCarter
RoxyCarter's Avatar
I'm not as smart as Bob, the excellent driver...
but I do have a manual trans stock zr1, and for the life of me I can't seem to keep up consistently with this other guy I know who has an automatic c7z.
My tires just slip and my traction control comes on and while im shifting gears, he is pulling away, and at best, I barely beat him, or we end up tying after I catch back up toward the end, or he just beats me.
What are your experiences in this arena Bob?
Old 11-18-2018, 02:31 PM
  #36
Mikec7z
Mikec7z's Avatar
NO it is more like MIKEROXYHESS is the legend race car driver in his own mind !
Nothing like bringing Roxy for support!
I think it was a saturday, no?
Bob has a lot of experience in this department Roxy, he is an excellent driver.
We know how fast the stock car is. So off base they say the Z06 with melted CAts is about as fast as the ZR1? Like anyone pay attention to those guys!Can you g
Can you guys honestly believe he managed to do this in a stock vehicle? I seriously can't fathom going that fast in a straight line!!!
He is a very talented excellent driver!!!
I have never been that fast in a quarter mile, if I had that time slip i would talk about it and post it over and over, and over and over....
Last edited by Steve Garrett; 11-18-2018 at 05:03 PM. Reason: Merged Posts-please use the Multi-Quote button in the lower right hand corner (the middle icon) to make your responses to multiple people look like this!
Mikec7z is offline
Old 11-18-2018, 02:41 PM
  #37
RoxyCarter
RoxyCarter's Avatar
Saying the same thing over and over means it's true though Mike!
Truth be told, I think Bob is having a meltdown right now because it is finally dawning on him that the information he told everyone about how a 2300 does not need a fuel system, is not true information, and if a person actually drives their car fast like the OP did, the car runs out of fuel.
I think it is finally dawning on him that his 20,889 posts of telling people about the perks of the 2300 and telling Mike his limp modes are a lie... Were all INCORRECT!!!
To Thew 228 code at 158 MPH
Old 11-18-2018, 02:54 PM
  #38
Mikec7z
Mikec7z's Avatar
well, i think it was you 3zr1z06 Bob accusing me of being Irun, and its a corvette forum documented fact that Irun had a twin turbo lingenfelter car with a tripple in tank RSI fuel pump, making over 850hp at the wheels, documented on video on the dyno... with a big wing on the back... so if I am him Bob, and you were right, then that means i had a 1000hp vette from that angle huh?
But lets assume Irun and I are 2 different people... is it impossible that 2 people on planet earth have 1000hp c6, and might have learned how to drive, long before they took a c7z around an exit ramp at 140mph pulling over 1 lateral G as they did so?
Nah, there is only 3z06zr1 Robert, and his amazing 2300 that teleports in fuel from another dimension, as he drives 160mph in the cold and KNOWS we are ALL WRONG!!!
The OP and i planned this conspiracy to drive you crazy. We knew that if a 2300 had a flaw, you would lose your mind.
Mikec7z is offline
Old 11-18-2018, 02:55 PM
  #39
3 Z06ZR1
3 Z06ZR1's Avatar
You are now apparently trying to change what i said, i actually said the reason my car is quick is because instead of it running rich like stock z06 and stock zr1, it now runs lean (more lean than any sane tuner would tune) but since i am under warranty and it is technically a GM tune still, i don't worry about it.
Why would you say your car is quick???
3 Z06ZR1 is offline
Old 11-18-2018, 03:02 PM
  #40
3 Z06ZR1
3 Z06ZR1's Avatar
well, i think it was you Bob accusing me of being Irun4cops, and its a corvette forum documented fact that Irun had a twin turbo lingenfelter car with a tripple in tank fore fuel pump, making over 850hp at the wheels... with a big wing on the back... so if I am him Bob, and you were right, then that means i had a 1000hp vette from that angle huh?
Nah, there is only 3z06zr1 Robert, and his amazing 2300 that teleports in fuel from another dimension, as he drives 160 in the cold and KNOWS we are ALL WRONG.
Nope wasn't me not sure who IRUN is? Never paid attention nor do I care. Keep with the legend in your own mind and your multiple personality's you seem to invent!
Just was saying Roxy posted you had 1000 hp Corvette's ? Talk to Roxy not me! Just had my Z06 in 20 degree's at 85 does that count?
3 Z06ZR1 is offline
Quick Reply: Thew 228 code at 158 MPH
