Borla X-Pipe install
Old Dec 1, 2018 | 05:13 PM
Ggpz06's Avatar
Ggpz06
Default Borla X-Pipe install
2018 z06 here wondering if I don’t have a lift can I still install the X-Pipe on my own?
Old Dec 1, 2018 | 05:37 PM
383vett's Avatar
383vett
Yup. Jackstand are fine
Old Dec 1, 2018 | 05:48 PM
MerakiAutoworks's Avatar
MerakiAutoworks
Supporting Vendor
Yes, just harder lol
-Josh
Old Dec 1, 2018 | 05:51 PM
Greg00Coupe's Avatar
Greg00Coupe
I used jack stands and parked the car over the center drain of my 2 car garage and took advantage of the drain slop.
Old Dec 1, 2018 | 07:35 PM
01Defense's Avatar
01Defense
I jacked up the passenger's side and installed with 2 jack stands.
Old Dec 1, 2018 | 08:28 PM
madrob2020's Avatar
madrob2020
It can be done on jackstands (I did my '16 Z). That being said, you need quite a bit of room. The larger you are the higher it needs to be. There is the large steel plate that has to be removed (about 28 bolts) & it is heavy & awkward to drop by yourself. Be sure to just loosen the 2 larger bolts that are in slots which allow you to remove all the other bolts, loosen last 2 in slots, then slide it to allow head of bolts to clear plate. Matching up the fwd pipe openings & gaskets is a bear also. It is overall a PITA & if claustrophobic at all you won't like it! Personally, if I did another one I would pay to have it done. So you might call around to get estimates. Good luck!
Old Dec 1, 2018 | 08:49 PM
jstewart's Avatar
jstewart
I did not try it. But then I am an old guy. If I had my quick jack at the time I think I would have.
Old Dec 1, 2018 | 09:02 PM
01Defense's Avatar
01Defense
Install depends on your comfort level. There are a few videos out there for your review. Check them out and make your decision. I did mine by myself and I took my time. Completed job in 4 hours.
Old Dec 1, 2018 | 09:07 PM
HooosierDaddy's Avatar
HooosierDaddy
I used the install as justification/reasoning for the purchase of a QuickJack as well. That made it much easier and now I have a lift too!
Old Dec 2, 2018 | 01:30 AM
1c8vette64's Avatar
1c8vette64
Super easy. I put mine on 4 jack stands. Took about an hour. Take out the tunnel pate bolts, x pipe hangers, two clamps that attach the x pipe to the axle back, and then the bolts and nuts that connect the factory pipe to the cats. Line everything up loosely and tighten up in reverse order. Once the car is on jack stands it's a super simple job.
Old Dec 2, 2018 | 09:22 AM
ZO6 cracker's Avatar
ZO6 cracker
Question on changing this out. Not sure if it matters to anyone. Does it void your factory warranty? Or change it back out if your car needs to go in for any work. Any help. Thanks.
Old Dec 2, 2018 | 09:33 AM
ZO6 cracker
Just got my answer from Chip!! All good.
Old Jan 3, 2019 | 09:57 AM
rsmith4604's Avatar
rsmith4604
I did the same thing. Ordered my Quick Jack, yesterday.
To Borla X-Pipe install
