AFM problem
Old Dec 4, 2018 | 05:04 PM
Konnor1212's Avatar
Konnor1212
Default AFM problem
Last week when I installed the AFM my battery almost dead then when I started driving the car it stuck in 4th gear I had to pulled over stop shut off the car and pulled out the AFM.What can i do beside not using the AFM?
Old Dec 4, 2018 | 06:16 PM
Thunder22's Avatar
Thunder22
If you're talking about the Range AFM disabler, send it back to Range for the later firmware.
Old Dec 4, 2018 | 06:35 PM
Konnor1212's Avatar
Konnor1212
Yes the AFM
ok thanks will send it out to them.
Old Dec 5, 2018 | 04:34 PM
madrob2020's Avatar
madrob2020
I believe the Range can tell you what firmware is installed by counting #of flashes when it powers up. I would imagine the instructions for finding what is installed on yours is on their website also.
Old Dec 5, 2018 | 05:42 PM
tertiumquid's Avatar
tertiumquid
Did you buy it direct from Range or from Amazon? The Amazon ones are usually not up to date on the firmware.
Old Dec 5, 2018 | 06:00 PM
Konnor1212's Avatar
Konnor1212
No I bought from a member here.
Old Dec 5, 2018 | 06:27 PM
tertiumquid
Then the other poster who told you to get Range to reprogram it will fix your problem. I have a new one direct from Range 3 months ago and it works like a charm and they're great people to deal with.
Old Dec 5, 2018 | 06:46 PM
Konnor1212's Avatar
Konnor1212
Ok will do, thanks
Old Dec 5, 2018 | 08:48 PM
383vett's Avatar
383vett
I just bought one from Amazon two weeks ago. The firmware was v8.6r1 which is the current one.
To AFM problem
