Z06 Tires Sizing
Cruising
Z06 Tires Sizing
Hello all,
I have a 2016 CC7 Z06. It has the factory Michellins on it:
335/25ZR20
285/30ZR19
I have been told TOYO R888Rs are really great tires. Mind you I am not concerned about the costs vs. performance at the track.
So I have researched the TOYO site and found the Proxes TIR, the Proxes T1 Sport and the Proxes R888R.
The Proxes R888R comes in:
325/30ZR20
295/30ZR19
Has anyone put these EXACT sized tires on a 2016 C& Z06?
Any issues with rubbing?
What do you think about the tire?
Thanks and happy holidays to all!
Slovak
335/25ZR20
285/30ZR19
325/30ZR20
295/30ZR19
Slovak
You might want to check out this thread from February from the Z06 section. It should have some helpful info.
Review: my Toyo R888 vs R888R
https://www.corvetteforum.com/forums...-vs-r888r.html
Here is another one I had saved:
R888R's for C7 Z06?
https://www.corvetteforum.com/forums...or-c7-z06.html
R888R's for C7 Z06?
RegnaR (12-19-2018)
Received 8,928 Likes
What are you going to use them for? Road Course, Street?
Here is what Toyo says about the tires:
Toyo Tires recommends the following general setup guidelines for the Proxes R888R:
Bill
- Operating Temperature: 160°F to 220°F
- Hot Inflation Pressures: 32 to 38 (psi)
- Camber: -1° to -3°
- Caster: As much positive as possible
Bill
Cruising
Bill
I want the R888R for road and track. I guy I work with has a GTR, 775RWHP and says they heat up fine.
I did some research and it appears that the following sizes are the best fit for a 2016 C7 Z06:
Toyo R888r
Rear 325/30ZR20
Front 265/30ZR19
335/25ZR20
285/30ZR19
The Michellins are just not what I expected based on the specs vs. performance. They are good tires but I am just not sold.
If anyone has put these on their 2014 + C7 Z06 please reply as I am concerned about rubbing on the front at higher g forces in turns. The back tires should be fine:
Toyo R888r
Rear 325/30ZR20
Front 265/30ZR19
Thanks to all for sharing, I REALLY appreciate it!
Have a safe holiday season!!!!
Toyo R888r
Rear 325/30ZR20
Front 265/30ZR19
335/25ZR20
285/30ZR19
Toyo R888r
Rear 325/30ZR20
Front 265/30ZR19
