HELP - Engine Temperature Sensor/160 Thermostat
Old Dec 20, 2018 | 11:50 PM
DZ07's Avatar
DZ07
Default HELP - Engine Temperature Sensor/160 Thermostat
How many of you all have experienced a bad Engine Temp sensor? My engine temperature gauge reads 0, my fans are staying on long after I park and my AC isn’t blowing cold air. I disconnect the battery and it goes back to normal. I just purchased a replacement today with the hope that this is the issue. I do have a 160 degree thermostat and I read that other were having the issue related to the thermostat, but nobody confirmed. Any input is greatly appreciated.
Old Dec 21, 2018 | 09:40 AM
djyankees31's Avatar
djyankees31
I experienced that initially when the tuner put in the 160 but didn't change the tune to reflect it. Once, I made the change in the tune I haven't had that issue since. However, most 160 thermostat's are crap including the high $$$. I've gone through 3 in less than 8 months and now using a 180 degree. I always keep a spare on hand since it's so easy to replace.
Old Dec 21, 2018 | 11:55 AM
musclesbmf's Avatar
musclesbmf
Where did you get said 180* t-stat? I have a 160 mishimoto and not sure i like how it performs.
Thanks,
Mark
Old Dec 21, 2018 | 12:13 PM
Bob U's Avatar
Bob U
Old Dec 21, 2018 | 12:29 PM
Thomasmoto's Avatar
Thomasmoto
I'm following this thread as well. I haven't changed mine yet, but have considered it.
Old Dec 21, 2018 | 12:59 PM
6Speeder's Avatar
6Speeder
This is pretty common every year when the temp drops. The ECM expects the ECT to come up in temp within a certain time (I don't know the time). When this doesn't happen it sets a coolant undertemp code (P0106 I believe), shows zero for temp, and runs the fans. It only happened to me when I was running a 160 stat and jumped immediately onto the freeway (where it takes longer for the ECT to come up). So, either do away with the 160 or let the car warm up a little before hitting the freeways.
Old Dec 21, 2018 | 08:13 PM
djyankees31
My second 160 was the mishimoto and it lasted less than 30 days. it's very poor quality for the price.
Here's the 180 that I'm currently running now.
Amazon Amazon
Old Aug 11, 2019 | 11:55 PM
ojulian's Avatar
ojulian
Cruising
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Best t-stat for C7 is the Katech brand 175 F unit. No need to reprogram and will not throw a code.
Old Aug 12, 2019 | 06:09 AM
ronsc1985's Avatar
ronsc1985
+1. All the rest are a malfunction waiting to happen.They also sell a 160 with the same design if that is what you want.
Old Aug 12, 2019 | 09:01 AM
BrunoTheMellow's Avatar
BrunoTheMellow
What I have done on my previous car and did again on my current car is buy a summit 170 tstat and press the bulb out and swap the bulb into the OEM tstat disc. This way you have the good OEM gasket with whatever temperature bulb you want.
Cruising temps vary from 172-178 dependent on ambient temps. Note that my car has an LG kit. A stock Z might run at 195-200 still.
I've ran almost 10k miles combined with both cars with no problems. Don't expect any problems either.
Here's a link on how to do it. You don't need a vise. Just sockets and a hammer or mallet.
https://www.corvetteforum.com/forums...he-rescue.html
Old Aug 12, 2019 | 12:20 PM
ronsc1985's Avatar
ronsc1985
The potential problem with doing that is the o.d. of the summit bulb is less then the stock piece. That means you have to try and swage the OE disc down to hold the new bulb.
I did this and it worked for about 6k miles but eventually the expansion and contractions from coolant temperature swings loosened the bulb. The result was it apparently got slightly sideways and would not open properly with the result the coolant temperature went rather high.
The Katech piece is a better option plus you will still have a working stock thermostat if you want to switch back for winter operation in colder climates.
Old Aug 12, 2019 | 02:22 PM
BrunoTheMellow
If you jam it in there. It seems the same effort as the stock bulb
Old Aug 13, 2019 | 04:42 PM
8850's Avatar
8850
I have instructions and pics of how to change out the 160 Mishimoto to the 180 Summit/Jet thermostat. Mine has been working fine now for over a year. If anybody want it PM me your email address.
Old Aug 13, 2019 | 09:11 PM
Joshinator99's Avatar
Joshinator99
The Katech is the only one you want to run. The quality is top shelf and I’ve never heard of a failure. My brother tried another off brand from a board vendor in his ‘16 Z06 and it didn’t even last 30 days before completely melting down and failing outright. He now runs a Katech 160 and I run one in my Whipple’d Camaro SS as well. Just not the place to cut corners IMO.
Old Aug 14, 2019 | 01:29 AM
db2xpert's Avatar
db2xpert
Installed the Katech a few weeks ago.
Perfect and no problems.with the stock tune.
Old Aug 14, 2019 | 07:31 AM
dar02081961's Avatar
dar02081961
Funny how things work out.
I did the bulb swap following 8850's instructions about 8 months ago. (approximately 12-14,000 miles)
All was well, temps ran a bit lower and I was perfectly happy and swore by this mod to all the folks I know.
However last week my temps started running a bit higher than I am use to seeing.
Car wasn't running hot but was climbing 20 degrees in 95* ambient temps after a hard run through 1st 2nd, and 3rd gears.
The temperature would come back down after the run but I confirmed with previous data logs something was amiss.
Checked for debris in the radiator fins and found nothing........checked the T-stat and found the exact thing you mention here had happened to my modified thermostat and bulb.
I was pretty deliberate and careful when I did the bulb mod, and perhaps I didn't secure it as well as I thought I did....who knows.
But my experience was exactly the same as yours.......It ran good for months and then it gradually failed.
YMMV.
Old Aug 14, 2019 | 07:50 AM
BrunoTheMellow
YMMV.
Interesting.
Old Aug 18, 2019 | 06:03 PM
GeorgeR_Zed06's Avatar
GeorgeR_Zed06
If you install a 160 t-stat and your car doesn't get to a certain temp after a certain amount of time, the car will throw code p0128. Your gauge will read "0" and your fans will run full speed, even after you turn the engine off. You either need to get a 180 t-stat, or get your car tuned. It happened to me with my '14 Z51 and once with my C7 Z06. I got it tuned out and no longer have that problem.
You have to go into "engine diagnostics" and check the box that says "no error return".
To HELP - Engine Temperature Sensor/160 Thermostat
