Got into a wreck with my 2016 Z06 and the airbag deployed. My ? is do i need a new module or after i replace the airbag can i just reset the module? watched a channel on youtube called goonzquad do a full rebuild on a 17 Z and they replaced the airbag and mentioned the module but never said what they did.
Just buy a new one. There's some people who claim they can clear out the permanent fault codes, but I wouldn't play games with something like this. You'll need to have someone program it too.
GDS2 can't clear airbag deployment codes. GM does not endorse re-using airbag controllers after a deployment.
Thanks. I knew you could use it to do the airbag serial number relearn on new ones but wasn't sure about reusing one. Probably better to just get a new one anyway.
