Transmission Control Module?
Old May 15, 2019 | 07:57 PM
dxbtune's Avatar
dxbtune
Default Transmission Control Module?
Can someone educate me on what this ecu does?
Old May 15, 2019 | 08:38 PM
laserdude2215's Avatar
laserdude2215
It's the Rear Differential Clutch Control Module.
Old May 16, 2019 | 10:38 AM
JHEBERT's Avatar
JHEBERT
Yep, controls the pump that uses ATF to pressurize the eLSD clutch pack to the left of the diff. Anytime the system is opened up (like replacing the diff) it will need to have the bleed procedure done using GM (or knock-off) hardware. HP tuners and EFI Live can’t help us here...
To Transmission Control Module?
