DSC Sport Controller Questions
Hi,
I track my Z06 on a regular basis and I had been looking for ideas/mods to make the car faster around the track. For now I think the car has plenty of power so suspension and aero are my main targets.
I have a few questions to people who use this unit.
What gains can you see in lap times?
Any problems issues?
If I upgrade to a ZR1, can this unit be transferred or not?
Can this work later if I also upgrade to their suspension?
Where is the best place to buy this unit?
Thanks a lot!
Thanks a lot!
Hi,
Thanks a lot!
Thanks a lot!
If you get the v4 controller it will also work in the ZR1 and yes the same controller will work with the Tractive shocks, you just need to upload a different "tune".
I know Katech is a reseller and I've bought mine direct from DSC Sport. I know there are others as well but I'm not sure which shops exactly.
When I first put the controller in the 2015 I picked up nearly 2 seconds on my best lap at the time at VIR. Now some of that was driver mod but overall I just had a lot more confidence in the car. Honestly, how much time you pick up (or don't) depends a lot on the driver and how easily you can adapt to the changes in the car.
Thanks for the input, I'll give them a call and order it.
Hi,
Thanks a lot!
Thanks a lot!
Do an "Advanced Search" of "DSC" in titles only in the C7Z and C7 General Discussion sub forums. You'll be reading for over a month and still not read all that's been written.
I will offer that it's the best mod I've ever made to any car and it's a relative bargain to boot.
You already have the most capable car. The DSC sport controller likely is no faster than the updated MRSC oem calibrations, which you have.
Really the only thing you need is to get 18s (or 18/19) and stick 315s up front and 335 or 345 rear. We discuss this a lot.
315/335 is the magic number for GS, Z06s. Other than that just get better. Show us some of your laps and we can see how far off pace you are.
You'd be better served doing your homework prior to posting the most basic of questions that have been answered ad nauseam over the last several years. I'm not meaning to be a smart *** but there are literally MANY thousand of posts thoroughly discussing every aspect of the controller.
My DSC arrives tomorrow, can’t wait.
Tires/wheels are next on my list but I usually change one thing at a time so that I can tell what difference that change made exactly. I have CC breaks and have to make sure the 18s will clear the breaks... looking for GS1R wheels.... by the way I didn't know you can fit 315 in the front ... 345 in the rear I read might rub on the track... have to research that a bit more.
Thanks for the input guys.
There is lots of info to sort through. Looks like you made a solid 2 second improvement from an already great time by adding the DSC. Was your car a Z07? I don’t have a Z07 and my car is absolutely mush when quickly transitioning weight while on slicks.
Wow, you’ve done a lot of work to your car. Firmer is definitely better on the track with wider tires or slicks. Unfortunately I have a little arthritis in my back and I daily my Z. The DSC should help.
Eventually I’ll daily another car and stiffen it up more. I had a GS Z07 and it handled great on the track. I may try that setup first. It has a larger front sway bar, the stiffer rear spring and the z07 front shocks. I thought it was a great combo, although it’s easier to control 460 hp rather than 650+
I saw you were doing the Hooker shorty headers also. Have you run it on the track with them yet? I just ordered a zero gravity 5lb battery. Will need to balance corner weights to get full benefit.
I also got a killer deal on the z07 setup from a friend. where I’m getting at. I think the dsc is great but the base calibrations I think they are for z07/fe7 based cars leaving the rest of the fe6 cars a little under damped. Due to our lighter springs and softer shocks. It’s better on track and the road now IMO.
The dsc calibrations make the Corvette waaaaay too floaty. This was true for both z51 and base Z06 springs. Z51 was unbearable. Any dip or rise on the road at 70+ mph was downright scary. This was even after attempting to stiffen it up. The Z06 was way too soft too. The base Z06 Tour mode is the best feeling street suspension. Just enough give on rough roads.
