Noisy lifters / valvetrain sound
Hi folks
Im not sure if this was always the case but today I opened up the hood after a long time and I could’ve sworn the clacking noise from the lifters is louder than usual. Car isn’t running too hot, engine is warmed up and idling, oil temp around 180F.
It almost sounds like the sewing machine sound that the C6 Z06 LS7 was famous for. My understanding is that the LT4 doesn’t exhibit this sewing machine sound normally.
Heres the video: link
Is this normal?
Is this normal?
Hi folks
Is this normal?
Is this normal?
DI engines are noisy. But it's hard to tell from the video. To me it sounds normal.
Hi folks
Is this normal?
Is this normal?
Tslavette—- sorry to hear about the magnuson issues on your grandsport.
Hopefully they were a stand up vendor on helping you with paying twice for labor.
TSLAVette (06-09-2019)
Thanks for the responses. In the video, the car is outside my home and not indoors. No echoes of any kind.
Also, I don’t hear any blower noise until I tap the throttle and I can hear the usual wheezing/whine of the blower. Does not sound like marbles in a can.
The clacking sound in question seems to be coming from both sides of the engine (and not from the top). I agree, it’s not too loud so I can see how it may sound like there’s nothing wrong. This is why it’s so annoying. It just sound slightly worse than normal (normal being when I first got the car), so it’s really hard to tell if this is just business as usual or if there’s a problem.
I’ll take it to my nearby dealer and have their vette tech check it out just to be safe.
Thanks guys.
Thanks guys.
I remember us talking from another thread last week. Is magnussson or the shop footing the bill? Is it covered under magnusson’s warranty?
Hi Gizmo and Hubris - thanks for asking; yes, they are taking care of me! It wasn’t easy but they are a stand-up outfit as is superchargersonline (Brian). Great people! I’ll keep you posted as swap is slated for wk of 6/17. Should be good to go! Also adding one of Mike’s TBs - Soler Engineering to assess better flow claims. We shall see!
Thanks guys.
Thanks guys.
My plan is to drive it and if something breaks, it will be covered under warranty.
Z0HS1CK (06-11-2019)
What you are hearing is injectors....they are quite loud. Hydraulic lifters only get loud if they collapse and then the car runs very badly as those valves are barely opening. There are lots of things that can change the sound of your car due to the sound being transmitted better or worse. On hot humid days sound will not travel as well due to the more spread out air molecules. If the air is cool and dry you may hear things better. There can also be echoes caused by the pavement below or a wall nearby or any number of things. I think that if you are not getting a check engine light or running poorly, what you are hearing is the normal sound of the injectors, and the only reason it sounds louder is where the car was sitting when you listened to it.
