Octane booster
1. If you don't have a tune for the octane level, anything above 93 octane will be useless to you (I forgot which Z06s have access to the factory racing fuel tune); and
2. The lead could kill your catalytic converters and probably not good for various sensors.
If you can use the octane, use racing gases without lead.
Scott
BOOSTANE FUEL ADDITIVE IS OCTANE ENGINEERING
Want the advantages of high octane gasoline without the hassle of trying to find it locally? BOOSTane is an additive that can bring 93 octane pump gas up to a tested RON of 110 when used as directed. Originally developed for the offshore powerboat market, it is safe for oxygen sensors and catalytic converters, and contains no alcohol to damage sensitive fuel system components.The Best of Corvette for Corvette Enthusiasts
Then, Start it to move it forward and shut it off, if there is a line of cars to get to the start line.
A cold lt4 is a fast lt4. Anything over 180 or 190 degrees and it starts pulling more and more power. Keep in mind, if you start at 160 degrees, by the time you do a burnout and make it to the end of the strip, you will be at 200 degrees.
You can't hardly get the thing too cold if you drive it to the track prior.
Octane has no use on a cold engine, only a hot one. But the car pulls timing and/or runs richer AFR (COT) regardless, even if it does not see knock, so the octane booster is useless unless the car is seeing knock, then it pulls EVEN MORE power if the knock is detected.
But the octane booster is not going to keep your car at full power. With a stock tune, only a cold engine with cold fluids keeps your car at full power. That is the only solution.
Want the advantages of high octane gasoline without the hassle of trying to find it locally? BOOSTane is an additive that can bring 93 octane pump gas up to a tested RON of 110 when used as directed. Originally developed for the offshore powerboat market, it is safe for oxygen sensors and catalytic converters, and contains no alcohol to damage sensitive fuel system components.There is a 100 octane tune the dealer can flash into the ecm for a price. Not sure that will help.
My lt4 runs best Luke warm about 160 degrees after I have been running it a while and let it sit 60 to 90 minutes. once it gets to 180 degrees or above it has a degradation in power.
bbvette.com an emerging vendor mentions the tune in his post above. That is probably the best solution for an otherwise stock lt4 to perform to the standard of an ls9 or ls7.
Octane has no use on a cold engine, only a hot one. But the car pulls timing regardless, even if it does not see knock, so the octane booster is useless unless the car is seeing knock, then it pulls EVEN MORE power if the knock is detected.
It does this to avoid knock in addition to Cat Over Temp Protection. (COT)
If knock is detected still, then obviously it needs to take more severe actions, and pulls timing and TB angle further.
In the beginning, it is TB blade angle which the engine limits and small timing changes also, if I remember correctly... and the car also changes its AFR to become richer... these all begin to happen by 180 degrees or so. Again, it is a gray scale... it gets worse and worse as the car gets warmer and warmer.
Keep in mind, COT is not a real detected value from the Cat's actual temps... instead, it is a calculated value, from engine oil, water temp, WOT duration times, etc.
COT is the process of the vehicle running AFR's intentionally rich to protect the cats. This is not optimal for power production obviously.
Most tuners will tell you that by the end of a FIRST WOT pull, when the car was cold at the beginning, the car will be into COT protection by the end of that pull, if not, by the second pull for sure.
These cars enter COT very quickly. It robs a car of 10-30 HP in its first phase it seems, and only gets worse from there. The COT is also a grayscale, becoming more severe as more heat is detected. This is why all of those dyno charts for air filters can be gamed by the vendors, they know if the car is cold, it makes more power than if it hot. Not saying none of the dyno's are accurate, simply saying COT being "OFF" matters more than what air intake a person puts on their stock car.
Eventually, once our cooling kits are out, we should be the least expensive option on the market to keep a vehicle out of COT as much as possible, while still allowing the customer to retain their factory warranty by keeping their factory tune. This area we can help. We plan to do the same things for the c8. This is why we are taking our time and doing things right. Cooling these cars down is the key to making the most power over a stock car in an apples to apples severe driving scenario, while also maintaining the factory warranty.
But to answer your original question, if you are willing to forgo your warranty, any decent tuner should be able to tune your car and shut off COT and also keep your TB angle open 100%, and also tune your car to take advantage or higher octanes. E85 is superior to higher octanes at keeping the engine running cool and avoiding knock. a 50/50 blend of E85 does wonders for these engines. The downside of e85 is you need more fuel pumps sooner, as you make more and more power, as it requires more fuel to have flowed vs normal gasoline.
I assume this is not a problem with an otherwise stock C7 Z06, correct? Meaning, the stock fuel pump can keep up at WOT. Reason being, I am considering a 160 T-Stat + E85 mod. I'm looking for 50 RWHP and more consistent power for a street machine.
I have HP Tuner mvpi3 to get the tune right for that set up. May also adjust COT as was mentioned here if the street temps are under control.
After completing a 1994 risk evaluation on the use of MMT in gasoline, EPA was unable, based on the available data, to determine if there is a risk to the public health from exposure to emissions of MMT gasoline. The Agency stated "Although it is not possible based on the present information to conclude whether specific adverse health effects will be associated with manganese exposures in the vicinity of or exceeding the [estimated safe level over a lifetime of exposure], neither is it possible to conclude that adverse health effects will not be associated with such exposures." This assessment was based upon the level of MMT allowed in U.S. gasoline.
A more recent test was conducted by the Alliance of Automobile Manufacturers (AAM) in the early 2000s. It was a 100,000-mi MMT test program using Ford Escorts and other light-duty vehicles. Ford completed a post-mortem analysis of the Escorts used in the AAM study. The AAM study found that MMT increased emissions of hydrocarbons (HC) over the entire 100,000 miles of testing, causing seven of the eight light-duty vehicles tested to exceed LEV certification standards. Nitrogen oxide (NOx) emissions were initially lower for MMT-fueled vehicles, but increased over time, as did emissions of carbon monoxide (CO), to become much higher than vehicles fueled with gasoline having no MMT at 100,000 miles. MMT increased emissions of all three pollutants at the end of the study by an average of 31-37% and reduced fuel economy over the life of the program by 2% or 0.6 mpg. The emissions impact of MMT was especially dramatic in Ford Escorts designed to meet LEV standards. Unfortunately, I could not find other key information about this test such as how much MMT was in the gasoline used for the testing and what were the condition of the emissions and engine parts as far as "plugged cats" and fouled spark plugs.
I've been unable to find any recent MMT test data or recent durability testing of emission controls parts of engines running on gasoline treated with MMT based "pour-in" octane booster products in the concentrations typically used by performance enthusiasts wanting to increase the octane of premium unleaded pump gasoline.
My unscientific survey of the market is that the most popular pour-in octane boosters amongst Corvette folks are "Boostane" and "Race-Gas".
On street, when I'm lazy sometimes I think at low speed, being in a gear barely above idle, I can pull from idle and just go. I noticed when on pure 91, there was significant bog and struggle for the car to go where when I had my mixture in the tank for 95, I never noticed off idle bogging that bad.
As for mixture goes, if you have access to unleaded race gas, use that first to do a proper mixture. I have bottles of boostane as well, but only bring up the octane when I'm doing track days.
