Front tire alignment
Old Jun 17, 2019 | 08:49 PM
Dale06's Avatar
Dale06
Default Front tire alignment
Is the alignment of front tires on a Z06 much more complex than others cars?
or more specifically, should I go to a chev dealer that specializes in Z06s, for alignment, or can a good chain tire store do an alignment?
Old Jun 17, 2019 | 09:24 PM
CMiller95's Avatar
CMiller95
They are no more complicated than any other Corvette of similar year, they utilize a double A-Arm system. Technically any alignment shop should be able to do it but that's dependent on the technicians they have. I would venture to a specialized Corvette shop just to know they know what they're doing, some dealerships are questionable. If you want to take the task on yourself you can check us out at:
https://csmperformance.com/home/
Photo of the front suspension:
NOTE: I do not own this photo, I found it on the forum
Colton @ CSM Performance LLC (Sorry used my personal account)
Old Jun 17, 2019 | 09:40 PM
Bill Dearborn's Avatar
Bill Dearborn
Should be easier than a BMW. The only issue is the rear caster measurement which isn't included in the alignment machine. Rear caster requires two more tools than the standard alignment usually has. A digital angle gauge and an adapter that adapts the gauge to the rear knuckle at the proper vertical reference.
Other than rear caster the alignment procedure and tools required on the C7 are identical to the procedure and tools required to align a C5 that is over 20 years old. No special expertise required, just common sense. I do my own and I am not certified to be any kind of mechanic. All it entails is turning bolts and watching gauges.
The reason some people charge a lot more to set rear caster is it is a touchy adjustment and it takes at least an hour more to do an alignment if you are measuring and setting rear caster.
Bill
Old Jun 17, 2019 | 10:39 PM
Dale06's Avatar
Dale06
Default Alignment
Thanks guys.
believe I’ll go to the chev dealer
To Front tire alignment
