Sponsored by: GEM Motorsports
CORDES PERFORMANCE-Thank you Maggie 2650 install
Old 06-28-2019, 10:43 PM
Freaked Ls3
Support Corvetteforum!
Freaked Ls3's Avatar
1006WHP @ 16lbs and stock fuel pump
The following 6 users liked this post by Freaked Ls3:
2highpsi (07-14-2019), ajrothm (06-28-2019), AK JOEY (01-06-2024), Monkey D. Luffy (07-11-2019), rjacobs (06-29-2019), ssmith512 (06-29-2019) and 1 others liked this post. (Show less...)
Old 06-28-2019, 11:38 PM
23/C8Z
23/C8Z's Avatar
Received 5,768 Likes on 3,180 Posts
Originally Posted by Freaked Ls3
Joe made an awesome deal on them Give them a call I am sure he can give you a shipped quote
So you're saying they're expensive? Lol.
Old 06-29-2019, 01:02 AM
rjacobs
rjacobs's Avatar
****** awesome...
was it out of fuel?
Old 06-29-2019, 02:00 AM
AZGASSER
AZGASSER's Avatar
Looks like the FIC injectors could handle the needs on their own.
Old 06-29-2019, 09:43 AM
NicD
NicD's Avatar
Well, we aren't stopping there. More boost to make, more fuel to use.
ajrothm (06-29-2019)
Old 06-29-2019, 01:11 PM
Bob U
Bob U's Avatar
Very impressive
Old 06-30-2019, 03:16 AM
Freaked Ls3
Old 07-07-2019, 01:50 AM
chuntington101
chuntington101's Avatar
Any updates?...
Mr. Gizmo (07-07-2019)
Old 07-07-2019, 07:45 PM
ckassen
ckassen's Avatar
Very good numbers... What pulley combo are you using? E85 or 93?
Thanks,
Chris
Old 07-07-2019, 08:09 PM
NicD
NicD's Avatar
Originally Posted by chuntington101
Any updates?...
Pretty sure still just waiting on the bigger high pressure fuel pump before going any further since it's going to need it.
Old 07-07-2019, 08:51 PM
Trackhawkz06
Trackhawkz06's Avatar
Awesome install... I have a maggy 2650 going on my trackhawk right now... and when thats done putting one on my vette! Great job!
Old 07-08-2019, 08:38 AM
DevilDog II
DevilDog II's Avatar
Oldtimer
Only 1,000 rwhp? My goodness, I'd kill myself in something with that much horsepower. Amazing!
Old 07-10-2019, 09:34 AM
  #33
NA FURY
NA FURY's Avatar
Does going with a Maggie like the 2650 help bring down operating temps (over the high-spinning stock Eaton) or no?
Old 07-10-2019, 03:33 PM
  #34
chuntington101
Lowering IATs or oil / water temps? IATs it might a little as the bigger blower isn’t working as hard. Probably see this more at higher HP levels. Also this blower looks to have MUCH bigger intercooler bricks than stock so they should help absorb more heat (don’t forget the bigger HE to help reject said additional heat).
as for oil / water probably not. You will probably be dumping a little more heat into the cooling air thanks to the bigger intercooler a bit then the blower is running a little cooler. So probably not a lot of difference.
Basically If you want cooling mods go search for cooling threads on here. There are loads of options out there (hint, hint: Katech zero cut option, GSpeed, DeWitts oil / aux coolers or 70mm rad, etc, etc!).
If you want 1000rwhp whilst still using a PD blower, look no further!
NA FURY (07-10-2019)
Old 07-10-2019, 03:42 PM
  #35
NA FURY
NA FURY's Avatar
I was thinking of oil / water temps. Thankfully I don't ever expect to have overheating issues with my '19 M7, but figured I'd ask since the these cars run hotter than most and the Maggies are popular choices.
Old 07-12-2019, 02:44 AM
  #36
Freaked Ls3
I’ll be sure to let you know when I get the car back if I have any overheating issues
Old 07-12-2019, 08:36 AM
  #37
CamOnlyJabroni
CamOnlyJabroni's Avatar
I’m sure Joe would help you address that. The only overheating problem you will have is the tires.
The following 3 users liked this post by CamOnlyJabroni:
AK JOEY (01-06-2024), samwint77 (11-13-2020), tripz (07-15-2019)
To CORDES PERFORMANCE-Thank you Maggie 2650 install
Old 07-13-2019, 04:03 AM
  #38
Freaked Ls3
With all the cooling mods done by the guys at CPR we added on this car you’re right hahaha
Old 07-13-2019, 02:13 PM
  #39
cajunboyz
cajunboyz's Avatar
Does the 2650 bolt right on( like the 2300?) to the C7 ZO6's, WHat RWHP are the 2650 giving with just 2650 blower, bigger TB, LT headers, Catless X pipe, A good conservative Tune on 93 pump gas only.
Old 07-13-2019, 02:19 PM
  #40
rjacobs
rjacobs's Avatar
i dont think anybody can answer 98% of your questions because there are like 10 of these blowers out there in peoples hands right now.
Quick Reply: CORDES PERFORMANCE-Thank you Maggie 2650 install
