P0106 Error Code
I have an aftermarket Holley Intake which is when all my issues started.
Here is what Onstar was able to check/diagnose as soon as my check engine light on:
ECM - Engine SystemP0106The Engine and Transmission System is not performing as expected. An issue has been detected in the Air Induction System which monitors and controls air intake to the engine. If the check engine light is flashing, a misfire condition has been detected. A misfire increases vehicle emissions and could damage the emission control system on the vehicle. Please reduce vehicle speed, avoid hard accelerations, avoid steep uphill grades, and reduce any cargo loads such as a trailer.
Is there a fix I can perform at home?
However, the check engine light resets after I turn engine on/off 3-4 times.
