Just finished up installing the Katech valve cover and coil relocation kit. Also installed a CFS Triple Pass radiator the quality and fitment of there C7 Z06 radiator is excellent plug, play no modifications at all.
Man, that looks really nice. From whom did you buy the products? Is there any advantage to the relocation other than appearance? Did you consider upgrading the coils and wires? Was the radiator pretty easy to install?
Really, really nice clean look -- I like it a lot !
Do you mind if I clip your pictures and take them by the Katech shop? I only live a couple miles away from them -- tom
I got the kit directly form Katech the valve cover, coil relocation kit and MSD wires. Comes with all hardware and gaskets nothing performance wise just a betted looking engine bay.
Radiator was not to bad just time consuming hardest part was separating the AC condenser form the OEM radiator.
