FRONT
Camber: -1.7 both sides
Toe: .05 Toe IN both sides <-- be careful some machines use "negative" value for toe in
Caster: 7.5 both sides
REAR
Toe: 0 Toe straight ahead
Caster: +.7 (make sure your alignment place can measure rear caster, they will need a special tool to do it, the alignment rack does not do it, you may have to repeat yourself)
