Stubility Control Help?
Old Jul 15, 2019 | 11:49 AM
Lukes07Vette's Avatar
Lukes07Vette
Default Stubility Control Help?
Hello all,
I am experiencing a situation in my Z06/Z07 with the stability control. The system seems to be kicking in at time it should not. I have read about a few people that have had the same kind of issue, but have not heard of any concrete resolutions. Seem that at anytime in Weather Eco, Tour, Sport, there is fare to much stability control intervention. This happens a lot on the freeway around 80mph and up if I have to turn the wheel, even slightly. Now when I say turn the wheel i mean in order the fallow the direct of the freeway. I know some might be quick to say that I am not used to driving a car like this, but it is my second Z06 and the situations where I am running into this are places where my previous Z06 would have no issue handling it at 30mph more then what I am currently doing in my new one. So it shouldn't even be fazing my c7 car.
Example: Driving on the freeway at 85mph with just enough throttle to maintain 85mph, slight turn of the wheel to fallow the freeway direction, .30g never exceeded on the meter in any of the instances, and the stability control starts kicking on and pulsing the rear brake.
Is this common?
Old Jul 15, 2019 | 01:32 PM
madrob2020's Avatar
madrob2020
I would try PTM mode Sport 1 in that same situation to see if it occurs. Sport 1/2 are less intrusive as I'm sure you know. Higher you go up PTM modes the less interference until they (nannies) are off in Race. Be careful tho in case there is a malfunction going on. No MIL/CEL I assume?
Old Jul 15, 2019 | 02:56 PM
Lukes07Vette
Yeah I am aware of that, It just seems to me that I shouldn't have to be in track mode to go above 80mph.
Old Jul 15, 2019 | 03:03 PM
madrob2020's Avatar
madrob2020
I probably wasn't clear. I was suggesting my idea to see if the problem still persist with less "intrusion", if it does then you definitely have a problem with software since no MIL. Good luck tho.
Old Jul 15, 2019 | 04:51 PM
mikegaan's Avatar
mikegaan
No. Not normal.
Old Jul 15, 2019 | 07:10 PM
Bill Dearborn's Avatar
Bill Dearborn
Hello all,
Is this common?
No it isn't common. It sounds like the stability system is sensing the car is under steering when you make that gentle turn. The first question I have is does it act the same way if you are turning the other direction? If it doesn't, does it not react at all or does it react in a different manner than the first scenario.
One thing that can cause that is an alignment problem. In all of the active handling diagnostics going back to the 98 C5 the first thing th mechanic is told to do is to check to make sure the alignment is correct and the steering wheel centered when the car is going straight ahead. If a thrust angle issue is causing your steering wheel to be off center (or if the steering sensor senses it is off center) when you turn the wheel the steering sensor could be seeing a larger displacement than is expected for the turn. The yaw sensor and lateral G sensors would indicate the car isn't responding as quickly as it should for that amount of steering wheel displacement and the EBCM would decide to pulse the inside back brake to get the car to yaw more. All this due to an alignment issue.
Stability control is simple. It tries to make the car do what the driver is telling it to do through the steering wheel. If something is out of line it can have trouble doing that. SC never fights a driver it only follows a driver's lead.
Bill
To Stubility Control Help?
