Uncork your AFE
Old Oct 9, 2019 | 09:27 AM
SpeedyVette's Avatar
SpeedyVette
Default Uncork your AFE
I just got an AFE intake to try on my Z06. I noticed right away they add a what looks like a piece of exhaust pipe cut 3/4 inch long and put it in inside the intake at the TB end for support. It looks like it is fine without it and with it in there it closes the intake opening too small. You can increase the tube end inside diameter by removing it.
Old Oct 10, 2019 | 04:40 PM
8850's Avatar
8850
The tube does shrink somewhat after the ring is removed. Just don't tighten the clamp too much or it's inside diameter will reduce even more. But good to remove it due to it only being 86 mm ID. Our stock throttle bodies are 87 mm but they do have the butterfly as a restriction reducing the effective diameter.
And easier way to remove it is with a heat gun. Little heat and it slides right out. How I removed mine.
Old Oct 10, 2019 | 05:20 PM
twostep361's Avatar
twostep361
nice ill try that,till I get me a 5"
Old Oct 13, 2019 | 04:54 PM
C7/Z06 Man's Avatar
C7/Z06 Man
When I bought my AFE that metal insert was made of aluminum which distorted (from time & clamp tightness) so I removed it and replaced it with some stronger and slightly thinner stainless steel tubing. I feel that you will stand a good chance of distorting the plastic tubing "over time" if you remove the metal insert which is there to stop the distorting. As far as performance goes my car runs pretty good with the insert on the stock tune.
SS insert pic with 2000° 'egg shaped' reflective tape on bottom of tube (out of sight) where heater hose passes by :
Old Oct 13, 2019 | 08:57 PM
SpeedyVette
I been driving mine a lot since I added the AFE. I feel a nice increase over stock!
I made sure not to over tighten it. So no metal needed.
To Uncork your AFE
