When will it stop!
Old Oct 30, 2019 | 12:21 PM
berryvette's Avatar
berryvette
Default When will it stop!
I bought at 2016 Z06 new and at 5k miles had to put a new rear end in due to failure, then at 12k miles i had to replace two rear cracked rims, then 14K the torque converter went out and now its back in the shop for a strong gas smell and looks to be the gas tank connections. So far all but the cracked rims have been under warranty and hopefully the gas tank issue is as well. Man i love this car but this one has had more issues than my 3 prior corvettes combined. Just needed to vent!
Old Oct 30, 2019 | 12:57 PM
383vett's Avatar
383vett
Gotta stop dumping the clutch at 5K at every stoplight.
Old Oct 30, 2019 | 01:10 PM
TJC333's Avatar
TJC333
Torgue converter. No clutch.
Old Oct 30, 2019 | 01:17 PM
f1reb1rd's Avatar
f1reb1rd
there is a bulletin on strong gas smell. hope this might be last problem for you. i;ve have a couple ghost problems with mine but they came once and never returned
Old Oct 30, 2019 | 05:38 PM
SilverGhost's Avatar
SilverGhost
You didn't get the letter? "Many are called, few are notified"
2014 - 2017 Corvette: Service Bulletin: 17469 Fuel Leaks at ...
https://www.corvetteactioncenter.com › tech › knowledgebase › print-1399
Aug 14, 2018 - Special Coverage Adjustment: This special coverage covers the condition described above for a period of 10 years or 120,000 miles (193,000 km), whichever occurs first, from the date the vehicle was originally placed in service, regardless of ownership.
GM Sends Letters to Selected Corvette Owners of Potential C7 ...
https://www.corvetteblogger.com › Corvettes › C7 CorvetteJun 5, 2018 - General Motors began sending letters to owners of C7 Corvettes to notify them of ... The extended warranty would only cover repairs to the fuel tank and ... if your Corvette has the new supplemental “Special Coverage #17469”.
if you love it, get the EPP warranty from GM/Chevrolet if not too late (before 3/36 expires)
Old Oct 30, 2019 | 05:43 PM
usrodeo4's Avatar
usrodeo4
Holy Mackerel...that is outside two standard deviations of the mean failure rates...I feel for ya dude. I just hope my '16 Z06 A8 with 5K miles stays clear of those issues. Just curious what is your pattern of usage?
Old Nov 1, 2019 | 09:53 AM
berryvette's Avatar
berryvette
No letter but i did some research and found the service bulletin.
Old Nov 1, 2019 | 09:56 AM
berryvette's Avatar
berryvette
Its a weekend car, not tracked or abused, I average about 3800 miles a year on it.
Old Nov 1, 2019 | 10:20 AM
383vett's Avatar
383vett
I meant neutral drop.
Old Nov 1, 2019 | 10:23 AM
2500 hd's Avatar
2500 hd
St. Jude Donor ‘18 thru '26
Damn, sorry for your problems.....
Old Nov 1, 2019 | 11:03 AM
Road machine's Avatar
Road machine
I don't mean to be harsh, but a rear end failure is a sure sign of improper break in. I know most of you all know way more than the engineers but this is what happens when you ignore the manual for break in. The torque converter in 16 had an issue but I don't recall what it was. I am sorry for the trouble you have had, but it seems that by 2019 (my year) they got the bugs out and mine has been trouble free....Knock on wood. That is why I tend to wait till the later model years in a new generation. Hell I may wait until the C9 to get a mid-engine vette....I think there are going to be a lot of issues with this entirely new platform on the 2020.
Old Nov 1, 2019 | 11:29 AM
ZO6 cracker's Avatar
ZO6 cracker
Sorry for the bad news. Yeah it sucks. I agree above post. Some guys complain about the issues with there C7 and dumping them. But I think there will be a lot with this C8. I would be shocked if there isn’t.
Old Nov 1, 2019 | 12:36 PM
SLEEKVET's Avatar
SLEEKVET
I hear you, and unfortunately I am one of those guys that dumped the C7Z and won't get a C8. I didn't even have the issues that the OP has. Personally I LOVED driving this car but with bent wheels, service lights, trans flushes, and the fighting with GM on warranty coverage, I totally lost confidence in future ownership. I got as much money as I could out of my Z06 after 3 years of ownership and banked it for now, saving for a future toy. I still lurk on the forum as it has a great bunch of knowledgeable people. We'll see what happens with GM's quality and I'll be checking in from time to time to see what is happening with the Corvette. OP good luck and hope all goes well for you.
Old Nov 1, 2019 | 02:11 PM
Mr. Gizmo's Avatar
Mr. Gizmo
c6 had the same fuel leak problem. Looks like it wasn’t addressed in the c7
Old Nov 1, 2019 | 02:35 PM
berryvette's Avatar
berryvette
In this case you would be incorrect with the break-in period, which i followed to the letter. When I talked to GM about the new rear end they were on back order due to issues and pulled one off the assembly line per the dealership that repaired it. I was told there was issues with a batch of rear ends and my vin# fell into that group but hey didn't know if all were affected.
Old Nov 1, 2019 | 02:43 PM
Dale06's Avatar
Dale06
That sux. Have not spent a dime on my 2016 with 19000 miles, except oil changes and gas.
Old Nov 1, 2019 | 02:59 PM
Road machine
While I do not doubt that you broke it in correctly and that the rear was defective, I said that because others swear that the break in is BS and makes you car slower....I just took the opportunity to point out why you do the break in. Sadly for you you had to do it again after the new rear.
To When will it stop!
Old Nov 1, 2019 | 03:53 PM
24/Eray's Avatar
24/Eray
The rear and the converter being broken in jacked up could be the issue.
OP. What's build date on car?
How many miles on it when you took it home?
And extended service stays before the rear went out? Anyone else drive it?
Just asking. To make a better assessment of your situation
Old Nov 4, 2019 | 03:18 PM
berryvette's Avatar
berryvette
The build date was September 2015 and i bought it November 2015 with 7 miles on it. The only service before the rear end failed was for general oil changes and tire balancing the dealership performed.
Old Nov 4, 2019 | 03:21 PM
berryvette's Avatar
berryvette
I was told today it is the Service Bulletin 17469 Fuel Leak and will be covered by warranty which is a relief, hope to have it back by the end of this week.
