Been searching for a new throttle body and have heard nothing but good things about the Soler performance throttle body so I was just wondering if I could get some more opinions. I will most likely be making my final decision in the next 24 hours so every opinion would help! THANKS!!
Do it, you will NOT be disappointed, and I've never seen anything but positive reports from members (including me) who have the Soler TB! You'll also get the fantastic customer support that Mike is known for.
Just installed a month ago. The best on the market. The best customer support. Mike at solar will take care of you, just as he did me. Worth every penny.
good luck as you can’t go wrong with this product and install was a breeze as well as excellent craftsmanship. Second to none.
I can only speak to the differences on a M7 transmission. The stock throttle body creates pretty sluggish off-idle response. The car wants to bog down unless you give it a good bit of throttle. The Solar throttle body solved that, and with the addition of the BMS filter (which I recommend) the response now is excellent.
I followed Solar's install and "learning" recommendations.
I was one of the first to buy the Solar TB. I think the serial number on mine is 60. 2K miles later and I'm still very happy with it.
yea I just ordered a afe intake so throttle body will be next, hopefully those two combined together with make it run smoother and much quicker!!
I have this combo on my car (2019Z M7), and I can tell you it is MUCH MUCH easier to drive at low RPM, low throttle angle. The Soler MTB TOTALLY transformed the way car drives. Fun factor was increased by a factor of 10.
Did anyone or everyone buy the Throttle Controller?
I believe you can also get the controller but it is not mandatory, I will be starting off with the throttle body alone and afe and seeing how I like that then possibly add the controller!
I installed the throttle body about a month ago. The throttle controller was on back order. I received the throttle controller but have not installed it yet. The ported throttle body really helped my 2016 Z06.
The off idle bog as far as I know all M7's had the issue but the latest ones don't GM seems to have fixed. My new M7 runs smoother take offs than the 2015 ever did.
The off idle bog needs this or at least a ported unit to fix it!
cant comment on the older cars but it made a world of difference on my late production 19M7
Combine with an AFE or Halltech intake is it going to cause my 17 to throw codes? All the comments about how sensitive the 17 is to mods have bme a bit nervous.
just got the AFE intake yesterday and I have a 2017 z06 I will be installing it this weekend, I asked AFE and they said if there’s any problems I can call and they can go over it!
