2300 install
Old Feb 15, 2020 | 09:24 AM
SpeedyVette's Avatar
SpeedyVette
Default 2300 install
I put them on several times. But this is the first time on a 2019
I put it on the Block.
Doesn't fully sit down on the passenger side.
Seems that the fuel lines underneath. Cause it so it won't go down.
the blower fit perfect on my 15
Old Feb 15, 2020 | 02:44 PM
T/A KID's Avatar
T/A KID
Get a pic... it should fit
Old Feb 16, 2020 | 07:45 PM
andreas g.'s Avatar
andreas g.
There is a tab that needs to be bent
to make it clear. I had to do it on my install so the SC would fit. It in the instructions booklet.
Old Feb 17, 2020 | 11:49 AM
SpeedyVette
the fuel Inlet line needs to bent down that bracket I've done that before but that's the only one I was aware of
so I was going to lift it up and put lipstick on the fuel line and then set it back down so I can see where the fuel lines hitting
Old Feb 18, 2020 | 11:52 AM
SpeedyVette
Got it on and all buttoned up and Magnuson customer service saw the thread and reached out to me with emails trying to help
it was just a case of the Factory fuel line just was sticking up higher than normal you could basically see that it was out of Tolerance
so after removing the charger I decided to take a two-by-four and a hammer and smack the fuel line and it brought it down to so everything fit nicely
put the charger back on and got it all bolted up with no issues
Old Feb 18, 2020 | 06:45 PM
need-for-speed's Avatar
need-for-speed
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03 thru '10, '17
doesn’t that go on the dipstick?
Old Feb 19, 2020 | 12:37 PM
99vetteran's Avatar
99vetteran
Hey Speedy I was glad to help.
To 2300 install
