Header install!
Old Feb 26, 2020 | 01:20 PM
SpeedyVette's Avatar
SpeedyVette
Default Header install!
I have put them on many times before. Never had to raise the engine.
This time it is a tight fit and seems the answer is to unbolt the motor mounts and raise the engine a 1/2 inch or so. Then right back down.
Is there a problem with doing this?
Old Feb 26, 2020 | 02:22 PM
us3rname's Avatar
us3rname
What headers are you installing? I got my long tubes in there fine by disconnecting the steering shaft of the drivers side and pulling it away, and removing the starter for the passenger side.
ssmith512's Avatar
ssmith512
Nope, no problem. That is what I did when I installed my headers. Easy peasy!
To Header install!
