Mods without tune?
I have a 2016 z06 and I am wondering how much I can do without a tune. So far I have added a Mamo ported TB, NX lid, have a corsa x pipe and AFE intake with dry and oiled filters ready to install. Do you guys think all of this is safe in stock tune? If the car doesn’t throw a CEL would it be ok?
I dyno after every mod to the engine. I do it because I want to know:
1. Did the mod add power as advertised?
2. Is my tune/combination of mods still safe?
Without doing this you are just shooting in the dark. You really don't know where you are at. Could be too lean, could be pulling timing, could be down on power, could be up on power. YOU DON'T KNOW.
How expensive was your car? How expensive would it be to replace your engine? Now compare that to the cost of a dyno. It's cheap insurance.
From my experience with my current C7Z, my C6Z, and my C5, the TB, the X pipe, and the lid SHOULDN'T affect your tune, whether they add HP you won't know. The AFE likely WILL affect your tune. The earliest AFE intakes for the C7Z ran VERY lean.
Dyno your car (use the same dyno every time). Make sure it's safe using these mods. Verify the mods are worth the money.
i am about 3 hours one way from a dyno. I haven’t installed the x pipe yet though.
No codes, but I did notice that upon initial start up, the idle was a little rough after I installed the ported throttle body. It eventually evened out after learning the new airflow.
I know the Corvette service manager at the dealership I bought my car and asked him at PDI about the planned mods and he told me any bolt-on mods that don't require a tune or resetting the factory computer are OK and will not void the warranty. After my first complimentary oil change, he also commented on how nice my (MGW) short-throw shifter felt as well.
I have the AFE cai and the new version of Tony Mamo’s ported Tb. Upon start up I didn’t really see or feel anything out the ordinary, idle was okay. My Z is an A8..Over 100 miles since Tb installed and nothing but smiles
Seems like these 3 bolt on mods are the most common choices to squeeze out any hp before tunning. Would be curious just to dyno at this point and see what numbers show up.
Every car responds different, but within range for your mods.
