Track mode display question
Old Apr 18, 2020 | 05:56 PM
Dr.Ron's Avatar
Dr.Ron
From: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
Default Track mode display question
I am wondering how the track display mode keeps track of current/best/last lap times and if it is accurate?
Does the PDR need to be on as well to get the data?
How does the car know the track or start/finish line otherwise?
Any info is appreciated!
Ron
Old Apr 18, 2020 | 06:16 PM
24/Eray's Avatar
24/Eray
You set start finish.
Yes same as pdr.
Timer only keeps laps when car is running.
If you shut car get out go back the track screen lap times will be 0.00 again.
If you recorded the session it will be on there. If not? Gone forever
Old Apr 18, 2020 | 08:45 PM
djnice's Avatar
djnice
I use the PDR and once on track set the start finish. The cars GPS maps the track. The lap times are automatically displayed and based on GPS position and seem accurate. Once you use it at a track it will automatically recognize it when you return at a later date.
Old Apr 18, 2020 | 09:49 PM
24/Eray's Avatar
24/Eray
Unless you format the card again.
There's a file on sd card once you set the start/finish. If you erase that file you erase the ability for the car to remember the position (so if you get a new sd card for some reason you need to transfer that file or redo start/finish).
Its obviously NOT the video or thumbnail o forget the format of the file but you'll recognize it being different and should be only 1 on card unless you saved multiple start/finish lines
Old Apr 19, 2020 | 09:19 AM
Elk's Avatar
Elk
The timing system is reasonably accurate.
Kimball Electronics makes the majority of the PDR hardware. They state the system employs a 5Hz GPS receiver. Click
At 100 mph, you are traveling 147 ft per second. With a 5Hz receiver the PDR creates a data point every 29 feet.
The lap times are accurate within roughly 0.2 seconds. (The total error can be up to 0.4 seconds per lap or as low as 0.0 if the system hits just right.)
Old Apr 19, 2020 | 11:00 AM
CaddyRacer's Avatar
CaddyRacer
I understand the PDR software can only handle one start/stop per memory card
so if you goto different tracks, get a memory card per track so you can compare times from different days from same track
...this is what I did......cheers
Old Apr 19, 2020 | 11:05 AM
Dr.Ron's Avatar
Dr.Ron
So as long as I set the start/finish line on the PDR, the dash display timers will work properly?
Old Apr 19, 2020 | 11:07 AM
Dr.Ron's Avatar
Dr.Ron
Thanks!
Old Apr 19, 2020 | 11:54 AM
Elk's Avatar
Elk
Yes.
Keep in mind you can set any route as the start/finish, including around your neighborhood.
Go out and experiment. It will quickly make sense.
Old Apr 19, 2020 | 06:21 PM
Dr.Ron's Avatar
Dr.Ron
Got it!
To Track mode display question
