Soler TB install snapped bolt
Old May 23, 2020 | 10:16 AM
FiftyFiv3's Avatar
FiftyFiv3
Default Soler TB install snapped bolt
I was installing the Soler TB and torquing the bolts down to 90 ft/lbs when a bolt snapped. Just ruined my Saturday. Best way to get the broken bolt out and where to find a replacement?
Odd that it snapped no?
Old May 23, 2020 | 10:30 AM
Elk's Avatar
Elk
Not at all odd it snapped. The throttle body bolts are to be torqued to 88 inch-pounds (7.3 foot-pounds).
FiftyFiv3's Avatar
FiftyFiv3
Wow big miss on my part there. Any tips to get it out?
Old May 23, 2020 | 10:32 AM
Elk's Avatar
Elk
A bolt extractor. It should not be too difficult as the bolts are pretty soft.
And we have all done these sots of things - obvious after the fact.
Old May 23, 2020 | 10:40 AM
Pacembellum's Avatar
Pacembellum
LOL WTF 90ft lb on a 10mm bolt...your first car really should not be a c7z when you learn the difference of inch lbs to foot lbs.
like step back for a sec and think should I be standing in my engine bay on my torque wrench to torque down a bolt half the size of a wheel lug nut.
Old May 23, 2020 | 11:26 AM
ClydeFrog's Avatar
ClydeFrog
Hopefully there’s enough aptitude to not snap the tap. Don’t use a shitty one.
Old May 23, 2020 | 11:29 AM
FiftyFiv3's Avatar
FiftyFiv3
Broken bit came out easy, off to find a replacement
Old May 23, 2020 | 11:33 AM
FiftyFiv3's Avatar
FiftyFiv3
Sometimes I impress even myself with my stupidity.
Old May 23, 2020 | 11:34 AM
ClydeFrog's Avatar
ClydeFrog
At least he stopped after the first one.
Pacembellum
hahaha you are a good sport. Good thing it wasn’t a head bolt! Good luck on the fix!
Old May 23, 2020 | 11:53 AM
Elk's Avatar
Elk
[Whew]
Now it is just an inconvenience rather than a problem.
Old May 23, 2020 | 01:24 PM
rico750sxi's Avatar
rico750sxi
dude, it happens sometimes... at least you got it out without issue. No harm, no foul.
Old May 23, 2020 | 01:26 PM
FiftyFiv3's Avatar
FiftyFiv3
Was able to locate a suitable replacement bolt, crisis averted!
Old May 23, 2020 | 01:47 PM
Elk's Avatar
Elk
Excellent!
If you do not have a baby torque wrench calibrated in inch-pounds, the bolts are not even tightened to snug (the bolt does not bottom out). They are just tight enough to start compressing the little green seal on the intake.
Be sure to post your impressions of the Soler throttle body.
Old May 23, 2020 | 06:16 PM
Maxpowers's Avatar
Maxpowers
OP - dont feel too bad. If you dont do a lot of mech work its easy to make this mistake. I once did too
Old May 23, 2020 | 06:31 PM
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
Getting ready to install mine tomorrow. I will not repeat your mistake. We live and we learn. I hope you can get the broken piece out and press on.
Old May 25, 2020 | 11:59 AM
Cowboy26a's Avatar
Cowboy26a
Use a 1/4 drive torque wrench. it will show the torque value you need. Harbor Freight has them for less than $15.
To Soler TB install snapped bolt
Old May 25, 2020 | 12:02 PM
Cowboy26a's Avatar
Cowboy26a
You are lucky it did not bottom out and destroy the threads.
Old May 26, 2020 | 07:30 PM
383vett's Avatar
383vett
Or warp the throttle body.
Old May 26, 2020 | 07:36 PM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
Don't feel too bad.. When torquing a bolt down always remember to tighten it until it breaks then back it off a 1/4 turn and it's good to go.. lol .. glad it wasn't too bad a situation.
