OnStar services
Old Jun 9, 2020 | 07:13 AM
Gee Venom's Avatar
Gee Venom
Default OnStar services
I received an email from Onstar services about my car yesterday and it had said the 2 left side tires were at 28psi. It also said the right front was at 27psi n the right rear at 24psi. I went to my buddies shop to put air and found out Onstar was wrong. Only had one tire at 29psi. My buddy had a digital gauge on his hose n I had a brand new hand held digital gauge which both showed the same readings as my buddy’s. Anyone else know had this issue? Thanks in advance
Old Jun 9, 2020 | 10:14 AM
laserdude2215's Avatar
laserdude2215
Probably just the difference between a cold tire and a hot tire.
Old Jun 9, 2020 | 11:46 AM
2ZORNOT2Z's Avatar
2ZORNOT2Z
I agree. The tire pressures will change rapidly on the OEM MPSS or Cup2 tires when you are driving. Depending on how far away your buddy's shop is, how warm it is outside, and how fast you were driving (highway?) to get there it could go up 3-4 psi over cold easy. Recommended COLD air pressure in the tires is 30 just FYI, that's why it was giving you an alert.
Old Jun 9, 2020 | 12:04 PM
RonC7's Avatar
RonC7
Put in about 33 - 34 psi when hot and then recheck / adjust cold tire pressures.
Old Jun 10, 2020 | 01:47 PM
dvilin's Avatar
dvilin
30psi cold and you should be good. As for on star their readings are accurate from my experience.
To OnStar services
