Cam install
Old Jun 30, 2020 | 10:15 PM
Sg mg's Avatar
Sg mg
Default Cam install
Had a cam install now oil leaking from timing cover mechanic says that been a problem with 6.2 wants to install a billit cover ?
Old Jun 30, 2020 | 11:46 PM
JUICED1's Avatar
0JUICED1
Former Vendor
Or you can go back and tell them to take the front cover off and re-seal it. If we had a leak on a car it wouldn't even be a thought....bring it in and get it fixed at no charge. I'm guessing they are just trying to re-coupe some cash.
I would look to see exactly where it's coming from first. On cars running more boost and no catch can (routed properly) you can spew oil out of the front main seal. When we take off the front cover we always install a LS3 front main seal (they are a direct fit). The LT ones are weaker and when you add boost they will fail.
Old Jul 1, 2020 | 03:53 AM
twostep361's Avatar
twostep361
i used fast fish seal
https://www.fastfishautoparts.com/st...ng-cover-seal-
Old Jul 1, 2020 | 05:51 AM
Jjagg0125's Avatar
Jjagg0125
I'm going to be installing my MM wild catch can, any tips for routing? Seems like there is a ton of different ways to route it.
And to the OP. Shop should fix that right for free. If you don't have the bottom of the timing cover very clean and the pan cery clean the silicone/rtv won't seal right... like on all ls motors as well
Old Jul 1, 2020 | 09:34 AM
Cordes Performance Racing's Avatar
Supporting Vendor
install error. And we have never had an LT front seal fail even on our 1500 HP builds...
__________________
Cordes Performance Racing aka "CPR"
Owner of AZ's premier LSX/LTX motorsports shop
http://cordesperformanceracing.com/
www.facebook.com/cordesperformanceracing.com
joe@cordesperformanceracing.com
480-359-5914
Old Jul 1, 2020 | 09:57 AM
SouthernSon's Avatar
SouthernSon
Not familiar with the front covers of the late model LT engines but on the C4 LT's one has to be careful about nicking the seal when installing. There is a special little plastic nozzle that is used to cover a drive to prevent nicking the seal when installing. I used it for cam swap on my LT4 and have never had a leak. I would suspect they had an installation failure. Their problem, not yours.
Old Jul 1, 2020 | 10:55 AM
Sg mg's Avatar
Sg mg
thank you for response will do
To Cam install
