Engine Oil
However I have seen in the past some national magazine 'engine' dyno testing where the viscosity of the oil was the 'only' change made using the same brand of oil to a thinner weight & keeping all the operating perimeters equal on the engine dyno. The resulting improvement was 30+ HP on a yester-year n/a not so high of a HP engine.
Then take into consideration that a thinner oil (requires less HP to turn the engine oil pump/s) will reach all the parts of an engine quicker reducing cold start up engine wear. However I have seen lately the exception where a 0w20 oil "Kicked A$$" in an oil test as far as engine wear goes on all the other "well respected" brands of oils regardless of the viscosity used.
BOTTOM LINE: "I" would use the thinness oil that still 'protects' from engine wear. The newer cars generally have tighter bearing clearances so they can maintain the oil pressure/layer with the improved thinner oils of today. Oh, and don't forget its easier (less drag) for piston rings to scrap thinner engine oil off cylinder walls. PS: it's also easier/less stressful to pump water than maple syrup.
https://www.speedwaymotors.com/Mobil...it,386340.html
I just picked up one of those 12 quart boxes with the pour spout at Walmart for $54
No filter but still, a filter sure isn't worth the additional $45
I also bought the “Franzia style” Mobil 1 0W-20 for my Silverado, but the ESP is not sold that way. Hopefully it will soon.
