Reduced power and P2101 code
Old Oct 8, 2020 | 07:10 PM
veni vidi vert's Avatar
veni vidi vert
Default Reduced power and P2101 code
I've had 2 instances where my car (stock other than a Solar TB) has went into reduced power mode. This time I was able to get a code reader on it and the P2101 came up.
I live at about 4K above sea level, and both times the code has happened was at sea level. Both times driving on the highway with low RPM's.
Does the collective think this could be related to the SolarTB and possibly a drastic difference in elevation? Would this be a symptom of having a leak as in I didn't get the screws tight enough on install? I know it may not be related to the TB also, so open for any ideas.
Thanks for any input in advance.
Old Oct 8, 2020 | 10:27 PM
Internets_Ninja's Avatar
Internets_Ninja
That is a common code for max effort ported throttle bodies. You can easily tune that out in HPTuners. But if you don't want to tune, you can either try the throttle relearn procedure or ask the seller to exchange for a less aggressive version.
Old Oct 8, 2020 | 11:03 PM
veni vidi vert
Will do and thanks again.
Old Oct 12, 2020 | 04:43 PM
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
My Z06 did the same. Contacted Soler and they sent me new TB the next day. Appears to be a common anomaly. So far the replacement has been trouble free.
Old Oct 13, 2020 | 08:35 PM
veni vidi vert
If the full relearn doesn't help I'll try that route.
Old Oct 13, 2020 | 10:28 PM
orrwhat's Avatar
orrwhat
Soler had a bad run of throttle bodies during their development which is common as they try to improve something already great.
The affected units are being replaced and Mike stands behinds his work.
Old Dec 20, 2021 | 10:47 PM
Orange_C7Z's Avatar
Orange_C7Z
1st Gear
Hey any update on this? I have an oem TB and keep throwing this code under full throttle. Thinking about slapping in either a solar, or oem TB and trying the relearn.
To Reduced power and P2101 code
