They are not the same size, but you can interchange them if you change the rotors with them. Or you can get a larger diameter steel rotor that will work with the carbon calipers. I don't know all the details, but just telling you the little that I do know.
djnice thank you. I should have asked the question differently: What does it take to switch from carbon to steel brakes without changing calipers? If possible.
