Have any of you have a problem not geeing a reading on pressure front tire but when i drive 20 to 25 mi. it comes back on always same wheel?
Sounds like you may have a sensor battery getting low. How old are the sensors on the car? One of the first indications of a low sensor battery is intermittent missing pressure readings. Especially when the sensor is cooler Vs hotter like it would be after driving 25 miles.
Bill
Battery really funny the problem 2019 z06 yet my 2005 work fine think your out to lunch nothing personal
Bill gave you the answer to your issue. Don't shoot the messenger you asked for his help.
The battery in the TPMS sensor for that wheel is starting to get weak.
I have TPMS sensors that are less than 6 months old and one of mine does this. Usually goes out for about 5-10mins then sees it again. Also comes back if I turn the car off and back on again. Doesn't always happen, usually only on longer drives.
The only time I had a similar problem was with a C6 GS and it only happened when my wife was using the USB port in the console to charge her phone. Couldn't give you any rational idea why that occured. You never know what might be related.
I had an 11GS that did that sometimes as well. I never checked the USB ports. May have been the same thing.
There is no battery so why waste peoples time with crap post what you know or say nothing.
