c7 z06 cam position sensor code P0016
Old Dec 31, 2020 | 06:15 PM
2017Z06's Avatar
2017Z06
Default c7 z06 cam position sensor code P0016
Hello,
I have a 2017 C7 Z06 fully built. Been recently have a issue with the cam position sensor code P0016 turns on when I put my foot into the throttle. The engine check does not turn on right away while driving fast. Car runs, ideals and no miss fire nor starting issues when code/engine check light is on. I have changed the sensor done by dealer and they said everything looks fine. When the code comes on i clear it and car runs the same fine no issues. Do you think I need to have my tuner turn off this code to stop keep coming on as maybe the high power I am making tripping the sensor?
Below is a list of my mods:
Magnuson 2650
Katech oil pump
Katech K 1 force cam shaft
Magnuson 103m supercharger snot
Katech ported heads with new lifters and timing chain
PSI high lift valve springs
Katech 103m throttle body
Valve covers
MSD spark plug cables
Katech spark plug covers
Katech valley delete cover
New spark plugs
Meth kit
e85 dual flex fule kit
Griptec 2.40" supercharger pully
ATI super damper
ATI 15% overdrive supercharger drive pully
Mighty mouse catch can.
AFE carbon fiber air intake
Auxiliary fule pump
Billy Boat headers
Billy Boat x pipe
Billy Boat exhaust
Larger intercooler tank
Micky Thompson ET Street S/S tires
Tune of engian and transmission
Old Dec 31, 2020 | 09:51 PM
orrwhat's Avatar
orrwhat
Im guessing if you have a cam lock out that the code will need to be turned off as the sensor is not seeing the full range motion of the camshaft.
Old Jan 2, 2021 | 11:24 PM
2017Z06's Avatar
2017Z06
What is cam lock out?
To c7 z06 cam position sensor code P0016
