Tune Question
Old Mar 10, 2021 | 09:26 AM
pokjws's Avatar
pokjws
Default Tune Question
Quick Question - I had my car tuned, but I now need to disconnect the battery for a short duration. Will that affect the tune I had done? Reason I ask, installing a ported SC. Planning on having the tune checked, but will it need to be totally redone? Thanks.
Old Mar 10, 2021 | 10:27 AM
Dr.Ron's Avatar
Dr.Ron
From: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
Pretty sure you would not lose the tune. The computer would need to be reflashed to lose/change the tune. Otherwise disconnecting the battery would wipe out the stock tune too then, no?
Others who have/do tune will chime in I'm sure.
Ron
Old Mar 10, 2021 | 10:32 AM
Dougpaper's Avatar
Dougpaper
Would not affect the tune in any way
Old Mar 10, 2021 | 10:37 AM
2ZORNOT2Z's Avatar
2ZORNOT2Z
You won't lose the tune, it is permanently flashed so it replaces the OEM tune. To go back to OEM you have to have it re-flashed back. You should have the tune adjusted after the ported blower anyway though, the A/F and boost numbers will likely change. Especially if you are porting the blower and moving to a 95mm or 103mm TB at the same time.
Old Mar 10, 2021 | 10:49 AM
KLG's Avatar
KLG
No worries with loosing the tune if you disconnect the battery. Although my C7 is not tuned, my Camaro SS and F150 are tuned and disconnecting the battery has never caused an issue.
Old Mar 11, 2021 | 08:39 AM
pokjws's Avatar
pokjws
Thanks for the replies and info, much appreciated
Old Mar 11, 2021 | 09:05 AM
pit-man's Avatar
pit-man
i think you just lose your short term fuel trims and they will relearn again after driving a little.
Old Mar 11, 2021 | 05:05 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Technically long term fuel trims, short term are always changing and not "stored" like the LTFT's. The long term trims are an average of the short-term.
Old Mar 12, 2021 | 09:02 AM
pokjws's Avatar
pokjws
Thanks for the info!
Old Mar 12, 2021 | 10:57 AM
pit-man's Avatar
pit-man
It figures I would have it backwards Doug..thx for the correction.
Pitt
To Tune Question
