19x12 vs 18x12 rear drag radials
I see where the diameter of our factor rear wheels and tires are 26.6 inches. Mickey Thompson drag radials in 305/35-18 on a 18x12 rim are 26.7" diameter. Mickey Thompson drag radials in a 325/30-19 on a 19x12 rim are 27" diameter. I though I have read changing the diameter of the fronts or rear significantly will give some kind of traction control alarm. Anyone have either of these options? I want to go to a drag radial with a taller sidewall and same look as the factory so I only have to swap out the rears and keep the front factory wheels and tires.
Subscribed...wondering the same thing.
The M/T ET Street R in a 325/35-18 (26.95") is about the closest you will find for a 18" rear. That tire isnt available in a 19" tire. The ET Street SS comes in a 305/35-18 (26.6") but gives up 30mm versus the stock width. I am in the same boat, I have a matching BC Forged 18x12 wheel coming so I can mount a set of drag tires on it.
I am looking at these for a 19x12 rim. Mickey Thompson ET Street S/S Racing Radial Tire - P325/30R19 the site claims 26.7" > am just curious how much taller the rear can be before I get issues with the traction control.
Those tires are going to be a 25.91" tall tire (26"). I looked at them online, just wasnt sure if I wanted a shorter tire. As of now my fronts are the OEM size 285/30-19 (25.73") and the rears are 325/30-19 (26.68" vs 26.59" stock).
123sugey (03-17-2021)
I've read about these issues from some members but can't recall exact trigger for the issues. I believe it was more with oversized front tires. A search will definitely turn up some results. That said quite a few guys are running the MT ET Street SS's in 345/35/18 which is a 27.5" tire with no issues, stock sizing up front.
From what a supplier told me, the compound is exactly the same from between the Street R and the SS, only the sidewall is softer on the Street R and the SS is better in the wet stuff.
Z06
Along the same subject line. Does anyone know if I can fit my existing 11"x18" (widened front C6 wheel currently on the rear of my C6 base with 305/35 18" MT drag radials) on my new to me '17 C7-Z06? I'm thinking they will stick better (stock HP) at the drag strip vs. the stock 335/25-20 MPSS tires (4 years old and 13K miles) that are on the car now.
Dig
Boat Racer (04-23-2021)
