Trans fluid temp question
Old Apr 15, 2021 | 12:47 PM
dckotwicki's Avatar
dckotwicki
Default Trans fluid temp question
2016 Z06
In normal driving on cool days My transmission temp barely registers anything.
On a warm day when the engine and oil temp rise (190f - 200f) I will see the trans temp rise above 100(?).
I just had the trans flushed and refilled and there is no change in its behavior.
This is not a concern but I am wondering if everyone experiences this behavior?
Old Apr 15, 2021 | 01:27 PM
Gucci Minh's Avatar
Gucci Minh
It's normal. Most of the heat that your transmission will experience for regular day to day driving will be from the exhaust pipes and ambient temperatures.
The harder the transmission works, the more heat will be generated (ex. high speeds fighting air resistance, accelerating hard without down shifting at a gearing disadvantage, etc.)
On the track it'll get real toasty.
Old Apr 15, 2021 | 01:30 PM
Gucci Minh's Avatar
Gucci Minh
Also, don't correlate water/oil temps to transmission temps. Your water and oil is circulating through a supercharged engine producing ridiculous power while it simultaneously regulates a thermostat - your trans temps influenced by other things.
Old Apr 16, 2021 | 09:00 AM
mmerle3's Avatar
mmerle3
The manual even says that when checking the level of your automatic transmission fluid it must be between 130 -140 degrees which I have found it very rarely gets in that range unless I’m driving it hard.
Old Apr 16, 2021 | 01:48 PM
Z06MJ's Avatar
Z06MJ
Mine does the same thing. I noticed through the winter months it would never move. Now that we are having a few warmer days, it will get up to 105 maybe 110 if I have been driving for a while. My concern is that it never gets hot enough to burn off any moisture that may be in the fluid.
Old Apr 16, 2021 | 05:56 PM
Gucci Minh's Avatar
Gucci Minh
You shouldn't have any water in your transmission unless you have infiltration from leak/damage. That would be a very bad sign though.
Old Apr 20, 2021 | 03:23 PM
Z06MJ's Avatar
Z06MJ
Gotcha.....I thought I remember reading before that the transmission fluid would attract moisture if it didn't get hot enough to burn it off like oil. Thanks
To Trans fluid temp question
