Disappointing on Dyno numbers
I had my 2016 C7 Z06 "dynoed" recently and had some very disappointing numbers. The technician said that there was a lot of slippage on the rollers. My rear tires and fairly worn out and nearing the end of their useful life. Could the worn tires be a factor in the low dyno numbers ???
NortonCO (05-01-2021)
Unless you've had your CAC circuit properly bleed, the way it came from the factory was likely full of more air than it optimally should have. When there is air in there your CAC pump can cavitate, sending signals to your ECU to pull timing. Mine pulled 5 degrees on my baseline pull. You don't get any lights or any indication that this is happening.
Slippage will really ruin the numbers. Would not trust dyno numbers. I normally do hp tuner scans with my dyno to read what my cars are doing during the dyno runs. If your car has a PDR, it can help tell you some things about the conditions too.
I can see where it slipped on the hit, but otherwise the peak numbers are SAE corrected and inline with what other stock Z06's make. (assuming your car is stock)
My car made 530rwhp and 540rwtq stock as well which is only +6hp and +3tq over what you have.
This seems normal to me.
Harbgrogan (05-01-2021)
Looks pretty normal, especially if you have an A8. The correction factor info isn't on the graph so that can also affect the end results. I think it's odd that you are having tire slippage issues with a stock Z06 on the dyno but you could always go back when you put new tires back there.
The following 2 users liked this post by XLR8TIN:
B747VET (05-02-2021),
Harbgrogan (05-02-2021)
Z06
