C7 Z07 Alignment Issues
BUT, it doesn't mean I don't like to enjoy driving my custom factory ordered 2019 Z07 Sebring Orange monster every chance I get. What is disappointing for me is the ridiculous tire wear I'm seeing. Corded and steel plys exposed on all 4 wheels at less than 13K miles, inboard side - due to excessive negative camber and probably in concert with other settings that exacerbate this condition during "spirited" driving.
This all started when I found my destroyed tires and bought new ones (stock Michelin PSS 285 front, 335 rear run flats on stock 19x10" and 20x12" wheels) - Note, I will get on my knees now and inspect my tires regularly going forward.
After much research, primarily on this site I concluded that I needed a mostly "flat and straight" (minimal negative Camber - 0.5 to -0.7 degrees front, -0.3 to -0.5 rear, Toe set to -0.03 deg. or so front and rear all around, and +7.5 degrees front caster and + 0.8 deg. rear caster), for my Strictly Street Driven car in Brevard Co. FL. (flat country)
These numbers, unfortunately, could not be achieved according to my local Bob Steele Chevrolet dealership technician in Merritt Island FL.
Nice guy, but he said that when he attempted to adjust rear camber to such "flat numbers" the rear toe goes positive (toe in). I asked what the rear Caster measurement was and he said, "they can't measure or adjust caster" here. He thought it would take a special tool. So he set the negative camber on the rear to the flattest setting he could and that was -0.9 degrees, both sides, and rear toe to -0.03 degrees both sides.
I didn't know there were these limitations to adjustment for the rear...comments appreciated.
For the front, I requested Camber -0.6 deg., Caster +7.5 deg., and Toe set to -0.03 degrees (toe out). He nearly achieved that with -0.7 deg both sides and met my caster and toe request.
I'm hoping to not destroy another set of tires in 13K miles so would appreciate all polite comments and recommendations on how to best maximize the life of my new tires. Don't say keep your foot out of it. The tires had NO wear on the outside of the tires I threw away. The "Before" camber on rear was -1.4 deg. left and -1.3 right, and front camber was -1.3 deg. left and -0.8 deg. right.
I'm wondering about my rear caster setting, and the overall rake of the car front to back with what I've read here. Might it be that my rear ride height is set to low? I've read 44 mm higher in rear and I don't think it's got that much rake.
And, why can't the rear camber be set to shallower/flatter numbers? Special tools? Special equipment? Remove washers on Upper control arms???
Thanks for your input.
-SubsonicVette
In the back, toe in is also better as the rwd pushes outward as it it accelerates, again nothing too drastic, you just want the natural bushing give to keep it relatively 0 while under load.
Using this with minimal camber 0-0.5 usually gave my C6 cars really good even tire wear. On my C7 z06, I'm running -1.2 camber and the tire wear is still good a year later (I'm going to be swapping out my rears due to cup 2's hitting end of life before I have any inner cord wear.
I've never had anyone complain that the settings I've requested is too hard to do on the corvette platform. It's just a bit annoying as changes to one side tend to influence the other side, but a good shop doesn't say its impossible, just takes the right time needed to do it right. Any shop that says otherwise is probably not giving you the right alignment which is why your tires are cording.
Bill
They were able to reduce the negative camber for both rear wheels to -1.4. and to toe to 0.01. The front tires are at -0.9 camber and toe set to 0.05.
They did indicate they couldn't reduce all of the negative camber of the Z07 suspension design.
I think you coule possibly get a 0 camber with an offset adjustment on aftermarket rims. By pushing the tire out farther, ie towards fender edge adds a small amount of positive camber.
I don't think the caster is too important for your use.
I am friendly with my guy so I am under the car with him when he does my alignments to the specs I bring. I make sure they're VERY close before I tell him that it's ok. And if I drive away and don't like the feel or if the steering wheel is off center I drive it right back and back on the rack I go! lol
Ron
https://www.corvetteforum.com/forums...-2019-zo6.html
