Cracked rim on a 2016 Z06
End result...
I took the wheel to my dealer. Was told the cost to replace was $1000. I was expecting $750.
I told them to get a replacement.
They took photos and sent them to GM.
GM responded saying they would pay $400... $600 to me.
I accepted the offer (as if I had a choice) and filed a complaint with the NHTSA.
My thought is if there are enough of these complaints the government will force GM to act.
This is the first time ever for me.
I hope it doesn't happen again. If so, I will look at replacement to a forged wheel.
End result...
End result...
Sucks that happened though. I have c7z wheels on my car and so far have been pretty lucky, knock on wood. I also have pretty flat roads in my area at least for my purposes of having fun in the car so I'm hoping not having a lot of bumps and cracks in the road will alleviate some of the causes of these cracks in wheels.
End result...
When I bought my Z I was worried about this. I purchased a set of signature forged wheels. They’re pretty close to factory and extremely strong. Luckily my stock wheels never bent or cracked. I sold them and it was about a $2000 difference between old and new.
$600 out of pocket seemed excessive.
The wheel was cracked and I felt as if they had me over a barrel.
Received 3,136 Likes
Finalist 2020 C7 of the Year -- Unmodified
Should be covered but will not be covered. If you paid $600 and it does not happen again for a long time you got off cheap.
Josh...im in the market for some new rims for my 2018 z06 bc of 2 cracked rims ....BUT is there really and truly any difference between the GM stock rims and fully forged rims??? driving around on the shitty, pot holed streets of Los Angeles with low profile tires, im thinking that both rims are a danger. But im definitely not the expert. What do you think? is there a guarantee if I buy rims from you? thanks boss....not knocking, just asking
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03,'04,'05,'07,08,'09,'10,’17
Our Titan7 wheels are a great replacement to the cracked OEM wheels, fully forged and won't break the bank..
https://www.corvetteforum.com/forums...ed-wheels.html
-Josh
-Josh
#34
That's what they do from normal dips and small obstructions that don't bother other cars, not even the Stingrays - this is a GS and ZO6 problem. They usually get bent first and you'll feel a vibration that's hard to pin down. The wheel, now being slightly out of round, begins to stress the high spot on every revolution and in time cracks the inner barrel edge. It will then slowly migrate into the air chamber and then the slow leak starts. That's when most owners find out they have cracked rim(s) or when they put on new tires. Search the forum and find that 1000+ comments thread and you'll quickly see how widespread the problem is.
#35
I spoke with Harlen Charles at Carlisle and he told me that the wheels on the new Vette are the same CAST wheels that are on the C7 ZO6s.!! Great move G.M. ! Putting shitty wheels on your new Vette! I have cracked 5 wheels already and now will buy a set of Forged wheels.
Thanks G,M, for a great car , however ,with shity wheels !!
need-for-speed (09-08-2021)
#36
