My air conditioner started blowing warm air on passenger side but driver side cooler. Still had to run ac on low with blower on max. I figure some internal baffles not functioning correctly. Any ideas on how to reset or whatever?
id probably cycle through the various modes and speeds to try to get it back, also ensure sync is on on the passengers side to ensure its the same and/or try to adjust that to show the same temp wise.
maybe also try turning it all off and again then try to cycle the modes. I would guess as well if its cold still sounds like baffling issue as you mention and I havent looked into much how these dual climate system are designed/work overall hopefully someone can offer more insight.
