Does anyone know if the heads have to come off for a cam install?
I plan on camping my zo6 in the spring and yes the heads most definitely have to come off. From what I've seen, the whole motor most likely has to come out as you have to remove the oil pan for the DOD delete as well and be stripped down to a short block. Not as easy as caming a LS motor.
Cool might as well ship them out for some porting then.
When I put my cam kit in I pulled the engine from the car. It is possible to replace the cam with the engine in the car by lowering the cradle a few inches and separating the engine from it. Then raise the engine as much as possible and remove the pan. People do it every day. You have to get longer cradle bolts to do it.
You are correct, the motor needs to be pulled tp do the job right.
Billy
