I was with a friend in Mexico and after a hard pull on the highway starting about 60 to around 156 mph and I heard what sounded like a backfire out of the exhaust with a slight loss in power. I slowed down and noticed the check engine light was now on not blinking but just on. I won’t be able to take it into the shop for a few days to get checked out, anyone have a similar experience? I have a 2017 Z06 with Corsa Xtreme cat back, x pipe, ported TB and CAI, tuned after all installed. This was the first time I’ve pushed the car this far and this happened. Any thoughts on what happened before I get it into the shop for a check would be appreciated. TIA
Just my guess: Low side pump prob couldn't keep the high side primed for the whole pull, high side pressure started to fall off, triggered the code when high side dropped low enough.
It is likely you popped the P0106 code.
Once verified do a search here on the forum for the P0106 code discussions.
GM came out with a fix for it that can be flashed at your local dealer.
