Reliability?
Different engines of course, but I'm trying to decide what my upgrade will be to from my current Corvette so I'm trying to factor issues and I know very little about the C7.
Thanks in advance.
Popular Reply
The C7 LT4 hasn't had several hundred failures like the LS7 had. I have been beating on mine since I got it 6 years ago. It has ~5000 track miles on it and it runs hard and long. Sort of like every other Corvette I took to the track. Beat the hell out of it for 20 minutes at a time, come into the pits/garage hop out of the car check the oil and forget about it until you are ready to go back on track again. As the old Timex ad used to say, Takes a Licking and Keeps on Ticking. I have been tracking Corvettes since 1992 starting with an 86, then a 97 followed by an 03Z, the 08Z, and the 15Z I have now. I have never changed a spark plug on any of them and the only failure I had was when the LS7 dropped a valve and GM replaced the engine under warranty. Even that isn't too bad considering 6 years of heavy track use and only one failure.
Bill
Thanks in advance.
these have been used in the corvette, camaro, and cts-v for many years now and they seem to hold their own.
Bill
Bill
While GM certainly has had its problems with quality, the LS engine is really shown itself to be a superstar ( well other than the drop valve thingy lol )
You do not see many people dropping coyote motors or hellcat motors into old pick up trucks and muscle cars. Most choose the LS and it’s for a reason. Probably similar reasoning as to why you see so many T buckets with small block Chevy‘s in them lol.
Bill
Get one !!
My experience with regard to reliability has not been favorable:
Torque tube failed and that damaged the clutch and flywheel.
Less than 100 miles later a lifter failed. The car is in the shop now getting them all replaced. The failure also destroyed camshaft.
I couldn’t use my warranty because I changed the fluids myself (not that an oil change has anything to do with a torque tube, but that’s why it was voided).
unfortunately being in CA I had to go back with all OEM parts. Idk if I should cut my losses and sell it to avoid another big expense or just keep it and hope for the best. My confidence is shot and my wallet is significantly lighter.
I know you have to pay to play. I was OK with that as far as a purchase price and consumables (which are also expensive) but if I continue to have major failures like this I may be done with Corvettes for good. Sad, because up to this point I thought this car would be in my family for generations.
what do you guys think? Did I just have bad luck or should I move on? I feel like these failures are far more common than what gets posted here.
to the OP; 6 months ago I would have said no issues go get a corvette it’s been awesome. Today, I would say only do this if you are ok with potential of very costly repairs. Hopefully some of this will be taken care of in the class action lawsuits, but I think it’s unlikely.
I'm so sorry you have had such bad luck:
1) The AFM/DOD system is a known point of failure (IMHO doesn't make it right to sell cars that way). Use a range device or have it tuned out to buy yourself time. If you do one of those two things you can have a pretty long motor life maybe even beyond what most owners expect to put on the car. The AFM lifters are the point of failure and they ALL will fail eventually.
2) Torque tube failures are not uncommon but yours seems to be very early and not typical of most owner's experience. I know it sucks to be you, but it is generally totally repairable and most owners don't tend to experience it until higher mileage and run hard.
The lifters will fail given enough cycles. It's an inherently flawed design.
If you have an M7 car, this time period will be longer. If you run your car hard and don't engage AFM often, this period will be longer. If you have an A8 and run in manual mode you'll buy more time. If you run a range device, you'll buy more time. If you delete the AFM via a tune you'll buy more time.
iI you wash and wax your car and never drive it 10k miles before you die, then yes, the failure will never happen.
The FACT is the technology is shitty and the lifters absolutely will fail eventually if the system is cycled enough times. I guess you could say the same of any mechanical component but the AFM lifters are a special case that fails earlier than just normal wear and tear of mechanical components.
