AC not working
Old Jan 23, 2022 | 05:43 PM
Derek Likos's Avatar
Derek Likos
Default AC not working
hey guys I have a quick video to show you my exact problem with the car, I traded in my c6 2 weeks ago for a 2015 c7 z06 and so far its been a pain in my ***, 1 cracked rim on the drive home and now my ac isn't working.
Old Jan 23, 2022 | 07:39 PM
dar02081961's Avatar
dar02081961
Hard to tell, but based on your video I would say that control panel is faulty.
The features you are missing are all controlled by internal circuitry within that panel.
Verify the lone connector going to that panel is fully seated. If it is, chances are its the control panel itself.
There could be damaged wires to the connector down stream somewhere but that is unlikely. However those wires will eventually need to be checked if the panel or nothing else becomes obvious.
Thank you
Old Jan 23, 2022 | 08:24 PM
Derek Likos
Thank you
thank you for the reply, I was thinking the same thing g sense my problem seems to be alittle different from people who have the actuator door problem, I’m hoping this will cost less than that ridiculous repair.
Old Jan 23, 2022 | 08:53 PM
Derek Likos
anyone else have this problem in the past ?
Old Jan 23, 2022 | 10:07 PM
dar02081961
Correct that is not a blend door problem.
The passenger control panel and seat heaters are in-operational.
They all only meet in one place. They are all controlled from within the main center control panel.
This is where your problem lies.
Old Jan 24, 2022 | 05:52 PM
Bill Dearborn's Avatar
Bill Dearborn
If you have access to a GM MDI Scan Tool use it to see if there are any HVAC codes. That will help guide you toward the cause.
Bill
Old Jan 24, 2022 | 10:11 PM
Derek Likos
Bill
Unfortunately I do not, looks like im just gonna have to take it to the dealer
To AC not working
