Flex Fuel & Header Combo
Old Mar 30, 2022 | 09:25 PM
CMG_19Z's Avatar
CMG_19Z
Default Flex Fuel & Header Combo
Hello all
I’m looking to add a flex fuel kit and long tub headers to my 19 Z06. I was wondering if this combo would work with the stock fuel system. I’ve read that I may need to upgrade and get a low side fuel pump because I could possibly run into fueling issues. Any help would be appreciated
Old Mar 31, 2022 | 08:02 AM
Buddy A's Avatar
Buddy A
It will work, probably won't be able to run full E-85. Would need to blend down to E-55-60. Still a nice power increase. I have a 15 and fuel pump started running low above E-55.
Old Mar 31, 2022 | 10:26 AM
Internets_Ninja's Avatar
Internets_Ninja
With a 2019 Z06 you don't need a low side solution as it has the ZR1 low side pump from factory. But a tuner that knows how to squeeze more out of the low side and high side pump will help stretch your Ethanol Content %. That said, E60 should be easily obtainable with those mods without upgrading the low side or high side on the 2019.
Old Mar 31, 2022 | 05:51 PM
Cordes Performance Racing's Avatar
Supporting Vendor
You will be able to run E50 which even if you could run full E85 it would make the same power. Do that with an aeroforce gauge to see the e content and our gauge pod to mount behind radio, and you're set! We do this combo a lot and usually see 85-90 rwhp gain over stock and most add in our expansion tank to ensure no air pockets.
https://cordesperformanceracing.com/...ideband-mount/
https://cordesperformanceracing.com/...-zo6-ice-tank/
__________________
Cordes Performance Racing aka "CPR"
Owner of AZ's premier LSX/LTX motorsports shop
http://cordesperformanceracing.com/
www.facebook.com/cordesperformanceracing.com
joe@cordesperformanceracing.com
480-359-5914
Old Apr 1, 2022 | 01:00 AM
CMG_19Z's Avatar
CMG_19Z
What if I also decided to add a lower pulley? Ex. The 720hp package from Lingenfelter.
Old Apr 1, 2022 | 09:03 AM
Supporting Vendor
you would be limited to e35-40. Not a big deal, but more blending so it depends on your threshold of what you're ok with doing.
Old Apr 1, 2022 | 09:24 AM
CMG_19Z's Avatar
CMG_19Z
That right there is the million dollar question lol
Old Apr 1, 2022 | 10:25 AM
CMG_19Z's Avatar
CMG_19Z
If I decided to do the lower pulley as well wouldn’t I need to upgrade my cooling bricks since I would be spinning the supercharger harder? And would I gain about the same amount of power with just flex fuel and headers as opposed to flex fuel, headers & lower pulley?
Old Apr 1, 2022 | 05:19 PM
Supporting Vendor
Stock bricks will be perfectly fine. With a pulley I typically see another 30-40 rwhp gain.
Old Apr 1, 2022 | 10:17 PM
dllhg's Avatar
dllhg
Hello all
I was about to do the same but had seconds thoughts on the whole E85. Unless you buy the expensive stuff in a barrel it is pretty dirty. Clogs injectors and apparently gums up other things.
I decided to just stick with 101 u leaded. Exhaust tips stay super clean. Clean injectors and similar power to E50 from what I have read on here. Now the price is t all that much more either lol.
Old Apr 2, 2022 | 12:38 AM
RegnaR's Avatar
RegnaR
lol yeah I am sure 101 unleaded is a little more than e85.
Old Apr 2, 2022 | 12:42 AM
dllhg's Avatar
dllhg
vs regular gas. 6.40 vs $10. Not a huge difference like it used to be.
I wouldn’t use pump E-85 after learning more about it. I have a flex sensor sitting on the shelf I was going to use too.
Old Apr 2, 2022 | 08:19 AM
ls1wolf's Avatar
ls1wolf
An easy rule with flex fuel is run a tank or two if E then run a tank of 93 to clean up everything.
been doing this for 3 years on my C6 and about to install a flex sensor on the C7 Z
Old Apr 2, 2022 | 09:25 AM
Internets_Ninja
Been running pump E85 for years and so have my clients, never even run a tank on 93. Never had any issues. Although in FL and TX the pumps always have fresh E85. Not sure where the stigma's came from about dirty and gummy. That hasn't been my experience.
Old Apr 2, 2022 | 10:34 AM
NITSOVER's Avatar
NITSOVER
Cruising
Not to get off the subject but . How come my brothers 2013 Cadillac Escalade can run E85 from the factory and the C7 Zs need a flex fuel sensor to be able to run E85?
Old Apr 2, 2022 | 11:57 AM
Internets_Ninja
Because the fuel volume required to run full E85 on the LT4 would have raised production costs due to needed the whole system beefed up. Additionally they met the performance goals on pump gas. It was answered somewhere on this forum by Tadge I think.
Old Apr 2, 2022 | 02:36 PM
NITSOVER's Avatar
NITSOVER
Cruising
Hey thanks man. i appreciate that info.
To Flex Fuel & Header Combo
Old Apr 2, 2022 | 04:14 PM
dllhg's Avatar
dllhg
I was told this by reputable Chevy service manager who does a lot of track cars and races himself at a high level. He ran e85 in his ZR1 and had to clean injectors once a year. I think he was running full e85. Perhaps mixing to e40-50 or isn’t as much of an issue. He said they don’t have the quality control on pump E85 like they do regular fuels. I did some searches and found lots of similar stories across a lot of platforms.
I just decided it wasn’t worth the hassle mixing and having to bring jugs to the track etc. tracks have pump 101. Decided I’d rather spend couple hundred bucks per track day and keep things simple.
Old Apr 2, 2022 | 04:18 PM
dllhg's Avatar
dllhg
I have also been reading you need to change oil a lot more often.
Old Apr 5, 2022 | 02:13 AM
bc928's Avatar
bc928
Lots of misinfo on e85. Been that way for 15 years.
