Pdr not working
Old May 15, 2022 | 02:10 PM
need-for-speed's Avatar
need-for-speed
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03 thru '10, '17
Originally Posted by Chris J
thanks for this info I'm going to by a 32 gb card tomorrow and see if that does it.
Thanks for all the great input I'll let you know if this works
CJ
fingers crossed for you
Old May 15, 2022 | 02:59 PM
Corvettemac's Avatar
Corvettemac
Originally Posted by LiManZ06
How big are the SD-cards and what FS are you formatting them with? My car had a 128GB card in it when I got it and I am unable to format it with a Fat32 filesystem, which is what the car requires. I got the "no card inserted" error too.
I bought a 64Gb card, formatted it Fat32 and it works just fine.
I’ve done this exact same thing and it worked fine as well. Do this OP before you do anything else ( if you haven’t done it already ) this solves 99% of the issues with the PDR not working .
Old May 19, 2022 | 11:07 AM
V8UPM's Avatar
V8UPM
Cruising
So, I have a FAT32 32gb 10 SD card. I have cleaned the contacts, tried thre differnct cards, all the right format and still nothing!! So frustrating, espcially as there is only 1 UK dealer and I am not sure they are that intereted in cars they didnt supply!
Old May 19, 2022 | 11:29 AM
LiManZ06's Avatar
LiManZ06
Can a PC read the card?
If you run out of options, perhaps I can send you a 32GB card that is tested to work in my car. That way you can tell the dealer you're working with a known good card tested in another Z06? I guess it's possible the card slot itself is bad or dirty.
Old May 19, 2022 | 11:58 AM
V8UPM's Avatar
V8UPM
Cruising
Yes, a PC reads all three of the cards I have used perfectly. I can even see that it is formatted correctly.
Not sure you would want to send a card to the UK but I apprciate the offer. I am sure I can find someone over here when I get to a meet! If not, I will try the dealer.
Old May 19, 2022 | 01:03 PM
LiManZ06's Avatar
LiManZ06
If you run out of options, let me know. It weighs a few grams, it wouldn't cost much to ship.
Old May 19, 2022 | 01:13 PM
V8UPM's Avatar
V8UPM
Cruising
Bless you. Thanks. I am sure I will find a way over here.
Old May 19, 2022 | 01:24 PM
Chris J's Avatar
Chris J
I have done this as well and I too am still getting the same result
Old May 19, 2022 | 01:28 PM
Chris J's Avatar
Chris J
If your willing I would love to try that option, Please PM me your info I will send you payment for the SD card, shipping and my info for you to send the card to me. This is a very generous offer and very much appreciated.
Chris
Old May 19, 2022 | 02:49 PM
V8UPM's Avatar
V8UPM
Cruising
Chris
Let me know how this goes if you do it @Chris J
Old May 19, 2022 | 02:51 PM
Chris J's Avatar
Chris J
I will do that for sure
Old May 19, 2022 | 06:07 PM
jc123's Avatar
jc123
Sorta sounds like when my phone wont charge sometimes because there is something in the slot blocking the connection. Take a can of air and spray into the card reader slot. Maybe there is a tiny bit of dust or something blocking the connection. Get it spraying first before aiming in the slot so you don't get any of that first initial frozen stuff in there. Hopefully it's simple like that.
Old May 19, 2022 | 11:52 PM
  #33
need-for-speed
CI 1-4-5-8-9-10 Vet
you tried a new 32 GB card, straight out of the pkg (no formatting) and it didn’t work?
Old May 20, 2022 | 12:20 PM
  #34
2001PewterWS6's Avatar
2001PewterWS6
I have a 256 GB card and used the free 3rd party software to format it. Works great and I have like 1500 hours of available video!!! Do a search on it that's how I found a step by step with what software to download to make it work.
Old May 20, 2022 | 12:25 PM
  #35
LiManZ06's Avatar
LiManZ06
There was a 256GB card in my car when I got it (used). The car couldn't see it. When I popped it into a PC to format it (with either the windows tool or several 3rd party tools), it showed up as something like 16Gb total. No amount of deleting partitions, formatting, etc. would work to be able to even see the full capacity of the card. I can only assume it failed internally somehow. These things are cheap consumer grade junk..When I bought the replacement, I bought several and formatted them and threw them in the glove box just in case.
Old May 27, 2022 | 10:15 PM
  #36
Chris J's Avatar
Chris J
Default Solved
Problem solved it was the formatting of the SD card. LiManZ06 went above and beyond and sent me an SD card he had used in his PDR so it was proven the SD card worked. I used a can of air to make sure the card reader was clean, installed the SD card he sent me and it worked perfectly. This is such a great example of how great the members of this forum are. Thank you all for all your ideas and help but again thank you LiManZ06, sending me this SD card was so kind I can't tell you how much I appreciate it.
Chris
Old May 27, 2022 | 11:16 PM
  #37
LiManZ06's Avatar
LiManZ06
Yay! So glad it works! Happy I could help you solve the mystery!
Old May 30, 2022 | 03:45 AM
  #38
V8UPM's Avatar
V8UPM
Cruising
Chris
Pleased for ya. No luck with mine still!
