So I think my splitter must have hit some road debris because there is a small gouge in it now. Strange because I didn't feel anything hit it while driving.
Anyway, is there a good aftermarket splitter you guys would recommend that looks exactly like OEM? It has to be carbon flash and stage 3 so my winglets will bolt up to it. Thanks in advance.
I have an EOS one and after a few scrapes on the passenger side, the "rolled lip" disintegrated. Paint is terrible where the texture of the material shows through the paint. Between that and the bad OEM design I got for their stage 2 winglets for my spoiler, I wouldn't go EOS again.
I have an ACS track splitter with integrated undertray now and it well worth the price. It is highly crack/damage resistant and installed perfectly, holes pre drilled and line up nearly perfectly (I had 1 hole to dremel a small amount)
Good info here, thanks for sharing OP, I have the ACS carbon flash stage3 splitter, the fit and finish are like OEM. Good Luck with your decision.
