Electrical issue? Bad alternator?
Old May 21, 2022 | 10:39 PM
CysZ06's Avatar
CysZ06
Cruising
Default Electrical issue? Bad alternator?
Hi all, looking for some help or insight
Started the car the other day and all the warning lights came on…. Rear axle system off, check engine light, traction control, rear camera fault, stabilitrak, all gauges are dancing around and flashing and you can even hear the exhaust valves frantically opening and closing. The parking brake is even tripping out and won’t engage properly.
im assuming I’m running into some electrical bug? I replaced the battery but the issue hasn’t gone away. Maybe the alternator or something isn’t grounded or shorting out?
Old May 21, 2022 | 10:44 PM
flying_vette's Avatar
flying_vette
or could be a bad spark plug as was the case with mine with similar warnings.
Old May 21, 2022 | 10:45 PM
CysZ06's Avatar
CysZ06
Cruising
Even just in accessory mode? If the car is off and you put it in accessory mode the warning still come up and you can hear the exhaust valves going nuts
Old May 22, 2022 | 11:18 AM
RonC7's Avatar
RonC7
Alternator / voltage regulator are not in play with the engine off. This sounds more like a communications bus or grounding issue.
GL
Ron
Old May 25, 2022 | 11:39 AM
Thomasmoto's Avatar
Thomasmoto
I have had 2 alternators replaced due to the same type of symptoms. 2016 Z06
To Electrical issue? Bad alternator?
