Octane Ethanol Question
Old Jun 7, 2022 | 05:13 PM
PolarBearLT4's Avatar
PolarBearLT4
Default Octane Ethanol Question
I've been running 93 Octane with ethanol (Chevron or Mobil) since I got my Z06. The Mobil station started carrying 90 octane which is ethanol free. Should I consider converting to the 90 ethanol free or keep the 93 with ethanol?
Old Jun 7, 2022 | 05:21 PM
NortonCO's Avatar
NortonCO
This question comes up from time-to-time. The short answer is it's more important to meet/exceed minimum octane requirements than to run ethanol-free gas. The longer answer is that, all other things being equal, ethanol-free gas is better (e.g., more stable, not subject to phase separation, etc) than ethanol-blended gas.
In your situation, I'd stick with blended 93 octane.
Old Jun 7, 2022 | 05:27 PM
PolarBearLT4
I thought that was the correct answer, but I figured someone here would be more versed than I. Thanks!!
Old Jun 8, 2022 | 11:52 PM
TJay74's Avatar
TJay74
I would always run 93 + E10 before I ran 90 or 91.
In Texas you can get 93 E10, in some states the 93 is made using 91 that has Ethanol blended with it to reach the octane rating of 93. Either way my data logs show that these engines need at least 93 octane, 95 octane would be even better but really doesnt exist without some special blending. When I do run 91 or 93 I always add a couple of gallons of E85 to the gas to up the octane rating.
Old Jun 10, 2022 | 05:35 PM
Thomasmoto's Avatar
Thomasmoto
I would stay with the 93.
Old Jun 11, 2022 | 08:53 AM
Zjoe6's Avatar
Zjoe6
I have 91 non ethenol available about 15 minutes from me and I prefer 93 with ethenol 5 minutes from me.
Old Jun 11, 2022 | 11:06 AM
Internets_Ninja's Avatar
Internets_Ninja
Higher octane fuel is always better for the C7. The only downside of Ethanol is lower fuel mileage but you actually don't see any drop off in mileage on modern cars until about E25-E30 and even then it is insignificant. Once you get to E40 the fuel mileage becomes very noticeable and just gets worse. 85% ethanol fuel will have a 30% drop off in fuel mileage.
Old Jun 11, 2022 | 11:54 AM
Thomasmoto's Avatar
Thomasmoto
Default Z06
I agree. That's right where my Z06 is now.
To Octane Ethanol Question
