MAP pinout needed
Old Sep 29, 2022 | 10:48 AM
DougHG8's Avatar
DougHG8
Default MAP pinout needed
I am installing a JMS fuel pump booster on a C7 Z06 and will control it via the boosted MAP sensor; I need the pinout/schematic for the MAP sensor so I tap into the correct wire and would appreciate any info!
Old Sep 29, 2022 | 07:14 PM
madrob2020's Avatar
madrob2020
If you haven’t, look at the C7 Tech/Performance section of C7.👍
Old Sep 29, 2022 | 09:27 PM
DougHG8's Avatar
DougHG8
I just checked but didn't see anything; I must confess though that I'm not too savvy at the search function. I set up searches for MAP pinout, MAP schematic, manifold air pressure sensor pinout, manifold air pressure sensor schematic, with and without quotation marks and don't find anything useful, but I may be doing it wrong.
Old Sep 29, 2022 | 09:32 PM
madrob2020's Avatar
madrob2020
My mistake, 🙄 I meant post your question there.
Old Sep 29, 2022 | 10:41 PM
DougHG8's Avatar
DougHG8
Good call! I'll post there! Thanks!
Old Sep 30, 2022 | 11:23 AM
dar02081961's Avatar
dar02081961
Here you Go.
Old Sep 30, 2022 | 02:09 PM
DougHG8's Avatar
DougHG8
Thank you! Perfect! Pin 4 it is!
To MAP pinout needed
