has anyone installed the fender well setup? any pics of the mounting bracket? grabbed a deal on a m/m catch can but with the intercooler engine bay tank im using the standard location the tank location or the radiator location wont work to mount the can so im left with the fender well. I have about 3 different brackets that came with the catch can just trying to see what else is needed to install it in the fender. if its a s simple as a piece of sheetmetal I can make one. pic on the website doesn't show me much
ok disregard this thread. m/m replied with the part I need. its the meth pump mounting plate they sell cheaper than my time to make one. ordered and done
would like to do a little update on this install since I scored a couple great pieces form a YouTube channel named "garageking" https://www.youtube.com/c/GarageKing. located in Canada this fellow enthusiast sourced a couple great fittings so you dont have to cut the lines from the t/b to run to the catch can you simply disconnect the oem push lock fitting ad this in its place and reinstall the oem push lock fitting NO CUTTING! there also a push lock fitting to run the new line to the catch can looks factory and 100% reversible if you want. the cost was 30$ for both pieces shipped to the usa if you allow him to use his 1 time a month postage discount. I wasn't in any hurry so fine with me.
im waiting on one more fitting to arrive and ill do the install in the fender and take a few pics. Dave at m/m sent me the bracket plate to mount the can in the fender cheaper than I could have made one!
