Cordes 5" intake?
Old Oct 29, 2022 | 09:59 PM
1QUICK Z's Avatar
1QUICK Z
Default Cordes 5" intake?
Hey guys, I'd like your opinion on the Cordes 5" cold air intake. It looks like a beautiful piece but I'm wondering if it's overkill for my set up?
I'm currently running a Halltech CAI, ported throttle body from Katech, off road pipes, Borla x-pipe, DSX flex fuel sensor (running around E40) and a 2.175 griptek upper pulley. My car has run a best of 9.8 at over 142 mph in the quarter, which I'm very happy about but we are never happy.
Thoughts.
Old Oct 30, 2022 | 10:54 AM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
No it would not, but what I learned with my Carbon Fiber Intake tube... you'll need to have it retuned again.. since sensor in a bigger tube.. unless maybe map sensor deleted in your tune already?
Old Oct 30, 2022 | 12:54 PM
Internets_Ninja's Avatar
Internets_Ninja
Unless your blower is ported and the snout is port matched to a 103mm TB, then no, a 5 inch intake isn't worth it. Personally, I prefer the Big Gulp 5 inch over the Cordes due to fitment. But you can't go wring with either one.
Old Oct 30, 2022 | 03:23 PM
DTOM's Avatar
DTOM
C7 of Year Finalist (performance mods) 2019
I also like that the Big Gulp doesn't require any cutting.
I just haven't seen anyone here with one or been able to see one in person.
Old Oct 30, 2022 | 04:39 PM
1QUICK Z's Avatar
1QUICK Z
Thanks guys. Who makes the Big Gulp? Rotofab?
Old Oct 30, 2022 | 04:44 PM
DTOM's Avatar
DTOM
Yes. Seems like a quality piece, but I've never purchased anything from them.
https://www.roto-fab.com/2015-19-cor...waAvPeEALw_wcB
1QUICK Z's Avatar
1QUICK Z
Ok, thanks!
Old Oct 30, 2022 | 07:55 PM
9sec's Avatar
9sec
biggest t/b is what a 112? thats 4.5" so a 5" still bottlenecks. most run maybe a 103? 4" again 1" bottleneck at the t/b. bigger isnt always better
Old Oct 30, 2022 | 08:46 PM
1QUICK Z's Avatar
1QUICK Z
That's an interesting point. What is the diameter of the stock throttle body? I tried to measure the diameter of the Halltech CAI but I don't have the right measuring tool. It looks to be about 4".
Instead of going up to a 5" cold air intake, does it make more sense for me to replace my ported (stock) TB with a 103mm?
Old Oct 30, 2022 | 09:32 PM
9sec's Avatar
9sec
its not a 1 piece fixes all . more air needs more fuel allows for more spark. its a combination of the right parts to have the best flow.
Old Oct 30, 2022 | 09:38 PM
Internets_Ninja
Unless your Supercharger snout is ported to match a 103mm TB, no. The supercharger snout opening is about 87mm.
Old Oct 30, 2022 | 09:39 PM
Internets_Ninja
I have one, its a very nice piece. Easy to install and no cutting of anything.
Old Oct 31, 2022 | 08:13 AM
speed4tu's Avatar
speed4tu
I have a Cordes intake and love it. The fit and finish is great. I have a 103 TB, along with heads/cam, etc and it works great. The cutting involved on the car is minor and you will never know it was done in the end. Rotofab wasn't an option a couple years back when i got it.
Old Oct 31, 2022 | 08:24 AM
Internets_Ninja
Yup the Cordes is a great choice. I've tuned many cars with the Cordes and it is just as good as the Big Gulp at making power. You can't go wrong with either.
Old Oct 31, 2022 | 12:39 PM
Cordes Performance Racing's Avatar
Supporting Vendor
At your current level you won't see much gain if any. If you were starting over it's easy to just snag ours up from the get go and be done. If you later port the blower then absolutely do the 5''. If you have any questions on it please don't hesitate to DM me.
__________________
Cordes Performance Racing aka "CPR"
Owner of AZ's premier LSX/LTX motorsports shop
http://cordesperformanceracing.com/
www.facebook.com/cordesperformanceracing.com
joe@cordesperformanceracing.com
480-359-5914
Old Oct 31, 2022 | 05:04 PM
Corvette4ever's Avatar
Corvette4ever
Just an FYI for the guys who may not like the minor cutting required with CPR supplied filter (K&N 2805XD). Volant 5118 air filter is very similar in dimensions except being 0.25" smaller at filter top (4" vs 4.25"). I have personally compared them side by side, no cutting should be required with the Volant filter
Old Oct 31, 2022 | 05:39 PM
DTOM's Avatar
DTOM
That's great to hear. Thank you! I'll likely go that route then due to no cutting.
To Cordes 5" intake?
Old Nov 4, 2022 | 05:15 PM
Chalky's Avatar
Chalky
St. Jude Donor '08-'09-'10
So Big Gulp and Cordes 5" is a push after your testing?
Old Mar 18, 2023 | 07:47 AM
Patastic's Avatar
Patastic
thanks for this, anyone know of any other filters, i dont think i can swallow that blue pill
Old Mar 18, 2023 | 09:03 AM
Internets_Ninja
You can't go wrong with either one. Cordes did it first. The shop I tune for installs more Cordes units overall. You will gain nothing by ditching your Cordes 5 inch for the Rotofab 5 inch. I wanted to try something different and went with the Rotofab 5 inch on my personal car. Other than the MAF calibration being a bit different, I noticed no differences in peak boost. I will say our fastest 60-130 C7 Z06's all run the Cordes 5 inch. but we haven't tested the intakes head to head so take that with a grain of salt.
